Battery Hooked Up - no smoke - but..., Starter doesn't turn |
lsintampa |
Jul 18 2013, 01:41 PM
Senior Member Group: Members Posts: 520 Joined: 28-January 13 From: Tampa, FL Member No.: 15,441 Region Association: South East States |
75 914/4 2.0
I worked up enough courage to hook power up to the thing. The instrument cluster is out, as is the dash top, and most of the wiring is just hanging down. Before I attached the battery, I did a once over to make sure I didn't see any shorts. Here's what works.... with the ignition on. Lights pop up and light, highbeams work, hazzards work, blinkers work, some annoying buzzer works (assume it is for the seat belts?), brake lights work, wipers work.... so it seems most things work. With ignition on - I don't hear the Fuel Pump come on, I assume it should run with ignition on (no tank in the car, yet - getting it sealed again). When I turn the key to start, I'm expecting the starter to engage, but it doesn't. Worth mentioning that the car basically is still very disassembled. The FI is not wired up - so I don't know if that effects the starter or not - I wouldn't think so. There were four red leads all that connect to the positive side of the battery, the long positive cable goes to the starter, and feeds another red wire that goes to the alternator / relay board. The voltage regulator is new. I'm not sure why the starter isn't engaging - it's new also, as is the alternator. Onward through the fog as they say. Len |
TheCabinetmaker |
Jul 18 2013, 08:54 PM
I drive my car everyday Group: Members Posts: 8,325 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
The lights go out when you turn the key to start.
ThePaintedMan |
Jul 18 2013, 08:57 PM
Advanced Member Group: Members Posts: 3,886 Joined: 6-September 11 From: St. Petersburg, FL Member No.: 13,527 Region Association: South East States |
Lo-Fi Version | Time is now: 6th January 2025 - 09:34 PM |
