McMark |
I picked up this 2.4 six awhile back and I'm gonna use this thread as I develop the engine which will eventually go in my gold car.
I'm starting a little out of order, but too bad. (IMG:style_emoticons/default/tongue.gif) So I have this aluminum flywheel. No manufacturer stamps or numbers on it whatsoever. I'm thinking that it might be too light for a street car, so I may not use it. It's about 3lbs by itself. I've got a 914 clutch adapter (basically a cut down 914/4 flywheel that bolts to the outer edge) and that brings the total flywheel weight to about 10lbs. I want a streetable car, is this thing too light? Attached image(s) ![]() ![]() ![]() |
Mike Bellis |
Resident Electrician ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,345 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None ![]() ![]() ![]() |
Longer runners will give you better low end torque. Shorter will move the torque curve higher typically.
What is your goal? Make sliding adjustable runners with O rings. Then tie a linear actuator to them. Control the actuator with an rpm counter to raise and lower as you drive... EASY! (IMG:style_emoticons/default/blink.gif) Mazda did this on racing engines. a NA 4 rotor did over 750hp. The RX-8 has multiple runners that are rpm/load controlled valves to lengthen and shorten the runners. |
Lo-Fi Version | Time is now: 28th June 2024 - 06:39 PM |
