McMark |
I picked up this 2.4 six awhile back and I'm gonna use this thread as I develop the engine which will eventually go in my gold car.
I'm starting a little out of order, but too bad. (IMG:style_emoticons/default/tongue.gif) So I have this aluminum flywheel. No manufacturer stamps or numbers on it whatsoever. I'm thinking that it might be too light for a street car, so I may not use it. It's about 3lbs by itself. I've got a 914 clutch adapter (basically a cut down 914/4 flywheel that bolts to the outer edge) and that brings the total flywheel weight to about 10lbs. I want a streetable car, is this thing too light? Attached image(s) ![]() ![]() ![]() |
McMark |
Okay, time for another thought/question. The engine is a bit unknown on the inside. Here's the story that came with it.
QUOTE 70T p &c's E cams 1969 Factory "S" heads a. Port size 36X35 38mm intake b. Valve size 45X39 1972 engine case Engine right side below shroud: *6123464 Question is, should I pull the heads off and check what all I've got? Maybe a valve cleanup job? |
Mark Henry |
that's what I do! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,065 Joined: 27-December 02 From: Port Hope, Ontario Member No.: 26 Region Association: Canada ![]() |
Okay, time for another thought/question. The engine is a bit unknown on the inside. Here's the story that came with it. QUOTE 70T p &c's E cams 1969 Factory "S" heads a. Port size 36X35 38mm intake b. Valve size 45X39 1972 engine case Engine right side below shroud: *6123464 Question is, should I pull the heads off and check what all I've got? Maybe a valve cleanup job? Slippery slope. (IMG:style_emoticons/default/unsure.gif) |
Lo-Fi Version | Time is now: 25th June 2024 - 08:39 PM |
