McMark |
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 20,179 Joined: 13-March 03 From: Grand Rapids, MI Member No.: 419 Region Association: None ![]() |
I picked up this 2.4 six awhile back and I'm gonna use this thread as I develop the engine which will eventually go in my gold car.
I'm starting a little out of order, but too bad. (IMG:style_emoticons/default/tongue.gif) So I have this aluminum flywheel. No manufacturer stamps or numbers on it whatsoever. I'm thinking that it might be too light for a street car, so I may not use it. It's about 3lbs by itself. I've got a 914 clutch adapter (basically a cut down 914/4 flywheel that bolts to the outer edge) and that brings the total flywheel weight to about 10lbs. I want a streetable car, is this thing too light? Attached image(s) ![]() ![]() ![]() |
McMark |
It's more about knowing what heads, cams, pistons and compression ratios.
I have been dying to build another six engine. This isn't exactly a build and I don't have the funds to actually change anything so it can't get too crazy, other than possibly adding spacers to lower compression so I can run dual turbos. (yeah, I have the disease) |
Lo-Fi Version | Time is now: 25th June 2024 - 10:34 PM |
