bondo |
Practicing my perpendicular parking ![]() ![]() ![]() ![]() Group: Members Posts: 4,277 Joined: 19-April 03 From: Los Osos, CA Member No.: 587 Region Association: Central California ![]() |
Ok, so I now know that for a good v8 5th gear, I need to put second gear in it's place.. flipped. 2nd gear is one 18 tooth gear and one 34 tooth gear. The 18 tooth gear is part of the mainshaft and not removable.
Then someone said the 904 mainshaft has no gears machines into it and all are equally swappable. But that is very rare, right? It's also more than I really need, as I just want the gear. But then it's been said that a 912 4 speed transmission has first gear where 2nd is on a 901, and the second gear is where third gear would be on a 901. Presumalbly this second gear is removable, and has the same splines on the inside as 901 gears. Is the ratio of this second gear something close to 18:34? Anything lower than 22:31 and it wouldn't be any taller than the stock 901 5th gear once it's flipped. I need sure answers here, I bought two 901s (no biggie, cheap) based on a statement something like: "you just flip 2nd gear and put it in place of 5th, and voila, taller 5th gear" which turned out to be nearly (see my signature) impossible. I do not want to buy a 912 4 speed to scavenge 2nd gear out of only to find it won't work or doesn't have the right 2nd gear ratio. (expensive) Just for the distribution of useful information, here are the ratios (tooth counts) of the stock 901 out of a 914 (side shift, but I don't think that matters) 1st (didn't count, but can if requested) 2nd 18:34 3rd 23:29 4th 27:25 5th 31:22 R&P 7:31 |
rick 918-S |
Hey nice rack! -Celette ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,507 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region ![]() ![]() ![]() |
QUOTE(propricer @ Jul 14 2004, 09:18 AM) Just got off the phone with PowerHaus II in Colorado who quoted me $ 575 for an H ( 19:32 ) gearset. They also advise that the stock 914 magnesium case is stronger than the early (65-68) 911/912 aluminum cases which is counter to what I had heard but this is their specialy biz and they should know. I bow to their expertise and apologize to anyone who I might have set astray. Further, they said that if you do use the early aluminum case, you have to flip the ring and pinion ! Sure makes hooking up a V8 complicated but still a lot cheaper than the 915 / 930 alternatives. A few more details please. As I understand, The 914 has a fixed 2nd gear on the shaft. If you get the "H" gear set from PowerHaus II in Colorado do you need to do anything with the 914 shaft or was this only discussed because our transaxles are not a source of "H" type gears because the gear is fixed? Is that question clear as mud? In other words; Anyone have a list of parts that are required to do the conversion? How about other parts commonly replaced during rebuild? (what bearing, syncros, seals, etc.) How about a source for getting these parts at a discount or best pricing? You know, wouldn't want to pay too much....... (IMG:style_emoticons/default/happy11.gif) P.S. What special tools are required to do the rebuild? And is there a source for a manual to do the work? And Who in the club specializes in rebuidling transaxles? and, and, and, and, (IMG:style_emoticons/default/boldblue.gif) (IMG:style_emoticons/default/boldblue.gif) (IMG:style_emoticons/default/boldblue.gif) (IMG:style_emoticons/default/boldblue.gif) (IMG:style_emoticons/default/boldblue.gif) (IMG:style_emoticons/default/coffee.gif) (IMG:style_emoticons/default/coffee.gif) (IMG:style_emoticons/default/coffee.gif) (IMG:style_emoticons/default/coffee.gif) (IMG:style_emoticons/default/coffee.gif) |
Lo-Fi Version | Time is now: 18th June 2024 - 07:54 AM |
