No power to wipers 1973-SOLVED |
HalfMoon |
Jul 29 2013, 06:19 PM
Senior Member Group: Members Posts: 828 Joined: 13-November 12 From: Shenandoah Junction, WV Member No.: 15,144 Region Association: MidAtlantic Region |
Hi all,
I just purchased a v-8 converted 914 and inherited a bunch of electrical problems So much for "turn key" and "daily driver" descriptions.... It will be some time before I can get this vehicle to pass our state inspections... The problems (electrical) so far, No power to right side headlight-SOLVED No horn (I don't even see a wire coming up the steering colum) Wipers not working Gas gauge not working Hazard lamps not working Front turn signals not working (Not even installed) Back up lights not working My first post of electrical gremlins (the right side no power to headlights) was solved rather quickly and so I thought I'd post my attacking the next problem, there's no power to any of the 5 wires to the wiper motor when the key is on and the wiper motor switch is activated on the steering colum. I don't see that this is fuse protected but I do see it on the circuit board (56, 91-optional intermittent). I'm guessing that it's not fuse protected. What test can we come up with that will tell us if the wiper is operational and beyond that (if it is) why is the switch not controlling it? Probably the relayor a ground fault I would guess, but first things first, how to test the wiper motor? Thoughts, ideas? Additional information-In another post I found that the relay for the wiper is supposed to be above the fuse panel and accessable by removing the two screws that hold the panel in. I did this but can anyone identify the relays and a test for same? Here's a picture- Also-the PO converted this to a v-8 and in a previous conversation with him about the circuit board, he alluded to the board no longer being useable during the converstion. I'm not sure if I inturperted what was being said....but I can't find a circuit board anywhere. Not being familar with 914's and having to wait for a manul from Amazon, wait for it (the dumb question), where would the circuit board be located? Assitional information-After examining an online diagram of the "relay" board, it appears as if the PO was right and (given that he removed all the heating stuff as it was no longer useable in a v-8 conversion) the relay board was no longer neccessary. That said, it appears as if the wiper motor is fused (and relayed-as it looks like I have the intermittent switch). Still hoping someone can identify the relays from my picture and mebbe have a test for that relay, but...and this is odd, one of the diagrams I've viewed (and I've posted it) indicates one of the five wires coming off the wiper (56) as going to a fuse block (60) with slots 8, 9, 10, 11, 12. That's confusing to me as I'm only aware of the 12 block fuse panel under the steering colum. Is there another one somewhere? Lol, can't wait for Amazon to deliver my 914 book :-( More info-learning curve. After much study I do not believe my wiper system had the intermittent switch and as such I shouldn't/wouldn't expect to see a relay for it. The diagrams indicate a relay is used only with the optional intermittent. Soooo, it appears as if the wiper motor is merely to a switch and it also appears as if it gets it's power from fuse panel position eight. I've tested the fuse and it's good, yet when I have the key on and the wiper switch on, I see no power at position eight on the fuse panel (either side). That's making me think the switch is bad, as I heard these fuse circuits are fused at the end of the circuit. Soooo, any cool ideas for testing the switch? Still might be of value to have a test for the wiper motor itself too. One of em is bad unless I've msitaken where the wiper motor gets it's power from (position eight). Attached thumbnail(s) |
JeffBowlsby |
Jul 30 2013, 06:33 PM
914 Wiring Harnesses Group: Members Posts: 8,781 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
Whats your real name moon-man? I like knowing who I am talking to.
Thats not an intermittent relay base, it looks like the fresh air fan connector. More later. |
HalfMoon |
Jul 30 2013, 06:43 PM
Whats your real name moon-man? I like knowing who I am talking to. Thats not an intermittent relay base, it looks like the fresh air fan connector. More later. My bad! Let me introduce myself...David Appell Pretty sure it didn't/doesn/t have the intermittent option. Stalk is a two position and I didn't see a relay where I thought I would see one (like on my LE, which does have it). While I am somewhat disappointed the level of electrical problems I've inherited, I must say, it is an exciting project. A little more than what I had hoped/planed on....but exciting none the less. Tomorrow I'll also put on the Roh wheels and tires I have around and a set of Recaro's. I'll be stoked if the hideaway motors operate without fail after I wire them tomorrow as well :-) Hopefully I can get this on the road over the next few weeks and sort out any other problems. Not exactly sure if I'll be keeping this one. If I do, I think it probably needs a fairly major work over and that would take away from the LE :-( Like I said, not exactly what I'd planned on. Btw, still waiting on papaerwork the LE :-/ |
Lo-Fi Version | Time is now: 27th December 2024 - 08:35 PM |
