Upgrade your headlight relay to electronic, How to wire up the new relay |
Mike Bellis |
Feb 16 2010, 10:42 PM
Resident Electrician Group: Members Posts: 8,346 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None |
The factory highbeam relay is a mechanical toggle relay. As they get old, they stop working correctly. It takes multiple pulls on the colum switch to engage the highbeams. Some may stop working completely.
Below you will see how to wire up an electronic relay. It's very easy to do. The very smart European builders have standardized their relay terminals. So many manufaturers relays will work. The picture below is a Saab relay. This relay can be found for $5-10 at junk yards. The 914 relay is about $50 You will need to jumper terminals 30 and 86 together with the 914 wire from terminal 30 Terminal 56a will go to the 914 Yellow headlamp wire Terminal 56b will go to the 914 White headlamp wire Terminal S will go to the 914 wire from Terminal S The final wire will be a new Ground wire you will add to terminal 31 That's it! You will now have an electronic highbeam relay. Now you have to figure out how to mount it. |
siverson |
Aug 4 2013, 10:56 AM
Advanced Member Group: Benefactors Posts: 2,451 Joined: 5-May 03 From: San Diego, CA Member No.: 654 Region Association: Southern California |
So this Saab relay is just used to replace the switch between high and low beam. That is, it doesn't provide a new power source to pull from for high wattage bulbs. Is that right?
So I could use this Saab relay to have an electronic toggle, but it's still a good idea to have a relay and new, larger diameter wire that is separately fused on the outbound side of things if high wattage bulbs are used. (I'm cleaning up my headlight wiring as I put my car back together...) -Steve |
Lo-Fi Version | Time is now: 1st January 2025 - 01:11 AM |
