tips or tricks for removing bezel on dash gauge, new questions...8/21 |
computers4kids |
Aug 5 2013, 06:38 PM
Love these little cars! Group: Members Posts: 2,443 Joined: 11-June 05 From: Port Townsend, WA Member No.: 4,253 Region Association: None |
I need to remove the bezel on one of my gauges to do some custom work. Do you have any tips or tricks for removing the bezel with the least amount of damage? The only thing that comes to mind is very carefully use a small thin bladed flat screw driver and work it slowly around the gauge under the lip.
toolguy |
Aug 6 2013, 09:56 AM
Senior Member Group: Members Posts: 1,270 Joined: 2-April 11 From: San Diego / El Cajon Member No.: 12,889 Region Association: Southern California |
When putting the bezel back on, I use a hand roller that is suppose to be for installing screen windows beading. . it has a roller with a little groove running down the middle. . . place the grove where you want the bezel to bend and roll it around 'gently'. . . makes a nice consistent curve and will straighten out all the little irregular bends you put in when removing it. .
76-914 |
Aug 6 2013, 10:12 AM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,514 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
When putting the bezel back on, I use a hand roller that is suppose to be for installing screen windows beading. . it has a roller with a little groove running down the middle. . . place the grove where you want the bezel to bend and roll it around 'gently'. . . makes a nice consistent curve and will straighten out all the little irregular bends you put in when removing it. . I liked your method of removal using the hose clamp. And this tip for re-installing one is just as good. (IMG:style_emoticons/default/beerchug.gif) |
Lo-Fi Version | Time is now: 18th June 2024 - 08:12 AM |
