McMark |
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 20,179 Joined: 13-March 03 From: Grand Rapids, MI Member No.: 419 Region Association: None ![]() |
I picked up this 2.4 six awhile back and I'm gonna use this thread as I develop the engine which will eventually go in my gold car.
I'm starting a little out of order, but too bad. (IMG:style_emoticons/default/tongue.gif) So I have this aluminum flywheel. No manufacturer stamps or numbers on it whatsoever. I'm thinking that it might be too light for a street car, so I may not use it. It's about 3lbs by itself. I've got a 914 clutch adapter (basically a cut down 914/4 flywheel that bolts to the outer edge) and that brings the total flywheel weight to about 10lbs. I want a streetable car, is this thing too light? Attached image(s) ![]() ![]() ![]() |
McMark |
The $2500 carbs I don't have? (IMG:style_emoticons/default/blink.gif) Life is so simple when you're spending someone else's money. (IMG:style_emoticons/default/laugh.gif) Plus, what do I learn from bolting on carbs. I'm not building a car. I'm building an education.
I've been wanting to start familiarizing myself with AutoCAD and this seemed like a good project for this since the intake adapters I'll need are relatively simple. I started with an intake gasket and scanned it. Then cheated and drew the outline in Illustrator since I can bang that out in about 2 minutes. Then imported that into AutoCAD and did the extrusion. It's pretty boring at this point. Gotta measure my actual intake port size, the OD of the throttle bodies, and decide on the height of the adapters I need/want. Then I'll start working on the actual tapered tube portion. Attached image(s) ![]() |
Trekkor |
I do things... ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,809 Joined: 2-December 03 From: Napa, Ca Member No.: 1,413 Region Association: Northern California ![]() |
The $2500 carbs I don't have? (IMG:style_emoticons/default/blink.gif) Life is so simple when you're spending someone else's money. (IMG:style_emoticons/default/laugh.gif) Plus, what do I learn from bolting on carbs. I was under the impression that this was an unknown condition motor that you were trying to determine whether or not it needed rebuilding. I have a set of carbs/manifolds you could borrow for testing off my 2.6 race motor. I still have that 6 into 1 tee pee off road exhaust for full effect... ![]() ![]() KT |
Lo-Fi Version | Time is now: 25th June 2024 - 10:13 PM |
