HalfMoon |
Senior Member ![]() ![]() ![]() Group: Members Posts: 828 Joined: 13-November 12 From: Shenandoah Junction, WV Member No.: 15,144 Region Association: MidAtlantic Region ![]() |
I think the PO removed it (certainly removed the horns and the horn buttons not connected to anything).
In order to pass inspection I have to wire in horns, but I want to identify/find the relay if it's still on the car. No idea where it's supposed to be located. Doesn't appear to be located on the back of the fuse panel (according to Haynes). Soooo, where izit, lol? Thanks! |
SLITS |
"This Utah shit is HARSH!" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 13,602 Joined: 22-February 04 From: SoCal Mountains ... Member No.: 1,696 Region Association: None ![]() ![]() |
Relay is one of the black round ones fitted to the fuse panel:
From Fuse #11 - solid red to terminal 30 on relay From Fuse #8 - red with white trace to terminal 86 on relay From relay - black with yellow trace from terminal 87 on relay to horn(s) From ignition switch terminal 37 - brown with white trace to terminal 85 on relay. Horn(s) are grounded to chassis at multi-ground 84? which I believe is under the headlight or 85 which is the chassis ground next to the fuse panel. The brown wire in the steering column comes from the horn ring behind the combo switches thru the steering wheel and connects to the horn pad. It is a ground. From a '73 wiring diagram .............. |
Lo-Fi Version | Time is now: 26th June 2024 - 02:11 AM |
