CV Joint Re-Hab, Done!!!! Down off the Jack Stands- Time to Drive |
914_teener |
Jun 21 2013, 06:14 PM
914 Guru Group: Members Posts: 5,250 Joined: 31-August 08 From: So. Cal Member No.: 9,489 Region Association: Southern California |
Ok...so ready to dip in and re-hab the rear suspension. Part collection is almost complete except new shocks. So a couple of question for the group since I have never taken the CV's apart.
I have read all the other posts and watched the CV You Tube rebuild, and a couple of questions came up in my mind. 1. As of right now there is no "clunking" so I assume that they are not overly worn since they are NLA. Should I just "flip" them when I am done upon reassembly? 2. Do I just flip them end over on the same side of the car? The video didn't explain it very well. So I would assume just reassemble them as they are now and them flip them right? 3. If I see bad pitting or fracturing....should I just look for a used one now and hang on to it? I have read about all the replacement options, must of them require some machining. I don't want to do this one again very soon so I want to make sure I do it right since the rest of the rear suspension will be getting re-habed. Thanks all in Advance: Rob |
914_teener |
Aug 13 2013, 11:08 PM
Okay....update.
Yes for all that have not done these.....they are not only a pain to find, but a nasty dirty job. I ended up going with the type I replacements as I could not locate any good used ones. Mine were so scored and pitted I didn't want to do them again anytime soon. Couple of additional questions for the World though some may have run into. 1. The Type I's have a recess here shown where the boot mates up against the CV. The fit up isn't great. Should I RTV this side so the boot won't possibly sling grease? 2. Going without the paper gaskets as I have heard stories from others that they will loosen the bolts over time. Any suggestions on the RTV to use? I was thinking the most grease resistant and temperature resistant possible. Thanks all in advance. |
Chris H. |
Aug 14 2013, 08:44 AM
Senior Member Group: Members Posts: 4,053 Joined: 2-January 03 From: Chicago 'burbs Member No.: 73 Region Association: Upper MidWest |
Yes for all that have not done these.....they are not only a pain to find, but a nasty dirty job. You got that right! Just did mine as well. Messiest thing I ever did on the car. Because of the massive 72hp power plant there was no pitting, scoring, damage, etc. Looked like new except for a slight shine shine in certain areas. They will probably shatter when I use them with the Subie. |
914_teener |
Aug 14 2013, 09:31 AM
Yes for all that have not done these.....they are not only a pain to find, but a nasty dirty job. You got that right! Just did mine as well. Messiest thing I ever did on the car. Because of the massive 72hp power plant there was no pitting, scoring, damage, etc. Looked like new except for a slight shine shine in certain areas. They will probably shatter when I use them with the Subie. Mine were shot....They were definitely the originals. I don't plan on putting any more than 120 horsepower through these. Thanks.....yes.... Kent.... understand the tension should keep all in place..... Thanks for the parts. All is key in keeping the parts in tension....my quess is that is why the engineers used the thicker backing plates to better distribute the tension from the screws. Any suggestions on the RTV on the other side......your right...I am not going to use the gaskets....hence the question. Thanks in Advance. |
Lo-Fi Version | Time is now: 6th January 2025 - 03:07 PM |
