> CV Joint Re-Hab, Done!!!! Down off the Jack Stands- Time to Drive
914_teener
post Jun 21 2013, 06:14 PM
Ok...so ready to dip in and re-hab the rear suspension. Part collection is almost complete except new shocks. So a couple of question for the group since I have never taken the CV's apart.
I have read all the other posts and watched the CV You Tube rebuild, and a couple of questions came up in my mind.
1. As of right now there is no "clunking" so I assume that they are not overly worn since they are NLA. Should I just "flip" them when I am done upon reassembly?
2. Do I just flip them end over on the same side of the car? The video didn't explain it very well. So I would assume just reassemble them as they are now and them flip them right?
3. If I see bad pitting or fracturing....should I just look for a used one now and hang on to it?
I have read about all the replacement options, must of them require some machining. I don't want to do this one again very soon so I want to make sure I do it right since the rest of the rear suspension will be getting re-habed.
Thanks all in Advance:
Rob
post Aug 16 2013, 01:53 PM
Rob, after you do this once you can be a professional like the rest of us. (IMG:style_emoticons/default/prop.gif)
914_teener
post Aug 16 2013, 09:33 PM
QUOTE(76-914 @ Aug 16 2013, 12:53 PM) *
Hah....no thanks I'll keep my day job Kent.
Everything fit up well. New bolts, schoor washers and shocks from PMB. New control arms all purty from Bruce Stone and bushings with zerks....gonna bolt everything in tomorrow.
Only thing I screwed up was the perches on the shocks. The hole is supposed to go towards the trans. This brought up a question:
When you re-install the spring, the Hayes manual doesn't say to or how much your should 'pre-load" the spring. It shows a spring compressor taking the spring off but doesn't mention putting it back on...what's the deal there?
Picture.....and yes...that is my daughters fingernail polish on the CV screws as tattletale marks.....just in case... (IMG:style_emoticons/default/laugh.gif)
914_teener   CV Joint Re-Hab   Jun 21 2013, 06:14 PM
ThePaintedMan   I just disassembled them, cleaned all the old grea...   Jun 21 2013, 09:11 PM
6freak   I just disassembled them, cleaned all the old gre...   Jun 21 2013, 09:51 PM
914_teener   I just disassembled them, cleaned all the old gr...   Jun 22 2013, 10:29 AM
rjames   You'll probably see pitting. If you do, replac...   Jun 22 2013, 01:14 PM
914_teener   Okay....update. Yes for all that have not done t...   Aug 13 2013, 11:08 PM
Chris H.   Yes for all that have not done these.....they ar...   Aug 14 2013, 08:44 AM
914_teener   Yes for all that have not done these.....they a...   Aug 14 2013, 09:31 AM
Racer Chris   1. The Type I's have a recess here shown whe...   Aug 28 2013, 06:28 AM
r_towle   1. The Type I's have a recess here shown wh...   Aug 28 2013, 06:46 AM
76-914   Rob, they never slung any grease out of that side ...   Aug 14 2013, 08:10 AM
cwpeden   Rob, they never slung any grease out of that side...   Aug 16 2013, 03:38 PM
76-914   Rob, I was trying to say they won't or didn...   Aug 14 2013, 04:06 PM
914_teener   Ok. Decided to use 500 degree and most grease res...   Aug 16 2013, 12:18 PM
76-914   Rob, after you do this once you can be a professio...   Aug 16 2013, 01:53 PM
914_teener   Rob, after you do this once you can be a professi...   Aug 16 2013, 09:33 PM
76-914   You did see where these are modified type 1's?...   Aug 16 2013, 07:06 PM
cwpeden   You did see where these are modified type 1's...   Aug 25 2013, 11:38 AM
914_teener   You did see where these are modified type 1...   Aug 25 2013, 12:42 PM
76-914   Yes and Erc along with others warned me. Being old...   Aug 25 2013, 12:45 PM
914_teener   ok. CV's are in. NO gaskets but black hi torq...   Aug 25 2013, 01:31 PM
914_teener   Whew....finally done after about two months up on ...   Aug 27 2013, 11:46 PM
wndsnd   Looks really good. One of the last jobs I need to...   Aug 28 2013, 06:12 AM
914_teener   :D Got it....might relapse! Had I known Dr....   Aug 28 2013, 09:18 AM
- Lo-Fi Version Time is now: 6th January 2025 - 03:09 PM
