Crank end play |
Crank end play |
jmargush |
Aug 19 2013, 06:08 PM
Member Group: Members Posts: 463 Joined: 8-June 04 From: Goshen, IN Member No.: 2,176 |
I am at the point of checking end play on the Crank.
When I first put the case together there was plenty of end play. Now there is not very much. Is this normal as pistons and cylinders are added things tighten up? when I push the flywheel in I set the dial indicator to 0 and then grab the fly wheel and pull it back. I get a .006" while pulling but when I let go it settles at.005". What is the correct measuring point under pressure or relaxed? Should the flywheel just be pulled by hand or pried lightly with screw driver? |
r_towle |
Aug 19 2013, 07:30 PM
Custom Member Group: Members Posts: 24,598 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
Shims are to be found at specialty parts shops for our cars, a flaps store won't have them.
The measurement is pretty important and makes the difference between a long life motor and a one day motor. Take the time to do it right. 914 limited in Peoria Illinois will have everything you need. Rich |
Lo-Fi Version | Time is now: 24th June 2024 - 06:16 AM |
