mig questions, sample pics added |
jimkelly |
Aug 21 2013, 10:29 AM
Delaware USA Group: Members Posts: 4,969 Joined: 5-August 04 From: Delaware, USA Member No.: 2,460 Region Association: MidAtlantic Region |
my original argon valve was bent up and leaked, so I ordered a new one. it had again, different sized threads, jeez.
so I went to ace ( r towel advice) and went with barbed fitting at both ends since the new argon valve came with a 1/4 barb already. question - when you are done welding and want to purge the lines of argon, after shutting the valve on the tank, do you have to waste wire or is there a way to purge without wasting wire? also, I expected the bead to stay at 15 psi when i turned the brass valve open, but it only rises to 15 psi or what ever I set it at, when I pull the red trigger on the mig - is this normal? also - I prepped some of my old real estate signs for practice : ) jim Attached image(s) |
Elliot Cannon |
Aug 21 2013, 12:23 PM
914 Guru Group: Retired Members Posts: 8,487 Joined: 29-December 06 From: Paso Robles Ca. (Central coast) Member No.: 7,407 Region Association: None |
I've never used anything other than .023 but I only weld 1/8 inch or less. I was taught that pulling the puddle makes for a deeper weld that pushing.
Lo-Fi Version | Time is now: 27th June 2024 - 09:01 AM |
