mig questions, sample pics added |
jimkelly |
Aug 21 2013, 10:29 AM
Delaware USA Group: Members Posts: 4,969 Joined: 5-August 04 From: Delaware, USA Member No.: 2,460 Region Association: MidAtlantic Region |
my original argon valve was bent up and leaked, so I ordered a new one. it had again, different sized threads, jeez.
so I went to ace ( r towel advice) and went with barbed fitting at both ends since the new argon valve came with a 1/4 barb already. question - when you are done welding and want to purge the lines of argon, after shutting the valve on the tank, do you have to waste wire or is there a way to purge without wasting wire? also, I expected the bead to stay at 15 psi when i turned the brass valve open, but it only rises to 15 psi or what ever I set it at, when I pull the red trigger on the mig - is this normal? also - I prepped some of my old real estate signs for practice : ) jim Attached image(s) |
speed metal army |
Aug 21 2013, 09:27 PM
Waiting for the rain to stop... Group: Members Posts: 1,068 Joined: 4-September 10 From: PNW Member No.: 12,137 Region Association: Canada |
Pushing is usually better..
An old fart used to tell us young fellas his philosophy on mig.. "What would you rather do?? Push your wire or pull it??" (IMG:style_emoticons/default/rolleyes.gif) Corny,but true. Practicing on uncut material is good. Laying beads, over and over. Then work on lap joints.. Tees. Outside corners etc. |
Lo-Fi Version | Time is now: 28th September 2024 - 02:29 AM |
