mig questions, sample pics added |
jimkelly |
Aug 21 2013, 10:29 AM
Delaware USA Group: Members Posts: 4,969 Joined: 5-August 04 From: Delaware, USA Member No.: 2,460 Region Association: MidAtlantic Region |
my original argon valve was bent up and leaked, so I ordered a new one. it had again, different sized threads, jeez.
so I went to ace ( r towel advice) and went with barbed fitting at both ends since the new argon valve came with a 1/4 barb already. question - when you are done welding and want to purge the lines of argon, after shutting the valve on the tank, do you have to waste wire or is there a way to purge without wasting wire? also, I expected the bead to stay at 15 psi when i turned the brass valve open, but it only rises to 15 psi or what ever I set it at, when I pull the red trigger on the mig - is this normal? also - I prepped some of my old real estate signs for practice : ) jim Attached image(s) |
Jeff Hail |
Aug 25 2013, 11:22 AM
Senior Member Group: Members Posts: 1,141 Joined: 3-May 07 From: LA/ CA Member No.: 7,712 |
Hey Jim,
Couldn't help but notice.. looks are you using 100% argon shielding gas? Jeff |
jimkelly |
Aug 25 2013, 11:39 AM
for a minute there - i thought - SHIT
but here is the label Hey Jim, Couldn't help but notice.. looks are you using 100% argon shielding gas? Jeff Attached image(s) |
Lo-Fi Version | Time is now: 27th June 2024 - 08:50 AM |
