CV Joint Re-Hab, Done!!!! Down off the Jack Stands- Time to Drive |
914_teener |
Jun 21 2013, 06:14 PM
914 Guru Group: Members Posts: 5,250 Joined: 31-August 08 From: So. Cal Member No.: 9,489 Region Association: Southern California |
Ok...so ready to dip in and re-hab the rear suspension. Part collection is almost complete except new shocks. So a couple of question for the group since I have never taken the CV's apart.
I have read all the other posts and watched the CV You Tube rebuild, and a couple of questions came up in my mind. 1. As of right now there is no "clunking" so I assume that they are not overly worn since they are NLA. Should I just "flip" them when I am done upon reassembly? 2. Do I just flip them end over on the same side of the car? The video didn't explain it very well. So I would assume just reassemble them as they are now and them flip them right? 3. If I see bad pitting or fracturing....should I just look for a used one now and hang on to it? I have read about all the replacement options, must of them require some machining. I don't want to do this one again very soon so I want to make sure I do it right since the rest of the rear suspension will be getting re-habed. Thanks all in Advance: Rob |
76-914 |
Aug 16 2013, 07:06 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,652 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
You did see where these are modified type 1's?? And they do come loose if you use a gasket. Guarantee it!!! It happened to me,
cwpeden |
Aug 25 2013, 11:38 AM
Great White North, huh? Group: Members Posts: 916 Joined: 20-August 06 From: Victoria BC Member No.: 6,693 Region Association: Canada |
You did see where these are modified type 1's?? And they do come loose if you use a gasket. Guarantee it!!! It happened to me, Ok, I see. Its the modified Type 1 thats the issue? Learn something new today. (IMG:style_emoticons/default/beerchug.gif) |
914_teener |
Aug 25 2013, 12:42 PM
You did see where these are modified type 1's?? And they do come loose if you use a gasket. Guarantee it!!! It happened to me, Ok, I see. Its the modified Type 1 thats the issue? Learn something new today. (IMG:style_emoticons/default/beerchug.gif) Yep.....torquing them down as we speak....another freakin hot day...... almost done. No problems except I forgot if the brake backing plate goes on the inside of the control arm and the caliper sandwiches against it? |
Lo-Fi Version | Time is now: 6th January 2025 - 03:32 PM |
