mig questions, sample pics added |
jimkelly |
Aug 21 2013, 10:29 AM
Delaware USA Group: Members Posts: 4,969 Joined: 5-August 04 From: Delaware, USA Member No.: 2,460 Region Association: MidAtlantic Region |
my original argon valve was bent up and leaked, so I ordered a new one. it had again, different sized threads, jeez.
so I went to ace ( r towel advice) and went with barbed fitting at both ends since the new argon valve came with a 1/4 barb already. question - when you are done welding and want to purge the lines of argon, after shutting the valve on the tank, do you have to waste wire or is there a way to purge without wasting wire? also, I expected the bead to stay at 15 psi when i turned the brass valve open, but it only rises to 15 psi or what ever I set it at, when I pull the red trigger on the mig - is this normal? also - I prepped some of my old real estate signs for practice : ) jim Attached image(s) |
jimkelly |
Aug 26 2013, 04:33 AM
yesterday I did weld on some flat metal. it turns out that not only are mig settings important, but hand travel speed is important too, and distance of TIP to metal as well. as stated above. not changing mig settings, I sometimes get a nice looking smooth melted bead, then the second pass was crap. I think this was do to hand speeds and distances not being kept consistent by me.
a mig may be considered the HOT GLUE GUN of welding, but there is more to it than just hoping for the best (IMG:style_emoticons/default/smile.gif) practice is crucial, thus having lots of clean metal to practice on is crucial as well. thanks guys!!! |
Lo-Fi Version | Time is now: 27th June 2024 - 08:51 AM |
