Rear spring shock install question, what have I done wrong? |
Type 47 |
Aug 25 2013, 05:11 PM
Senior Member Group: Members Posts: 788 Joined: 1-June 10 From: St. Louis, MO Member No.: 11,790 Region Association: None |
Installing new Bilstein shocks with 140 lb springs. took off stock springs with Koni's with a spring compressor. I didn't really need the spring compressors for the Bilstein's and now they slip off the bottom cradle. The Bilstein cradle is flat where the Koni's is more formed, like the top piece from the car.
What am I doing wrong here (note I installed them backwards to see it there was a difference). which reminds me...which end is up the small coils or the larger? (IMG:http://www.914world.com/bbs2/uploads_offsite/i139.photobucket.com-11790-1377472264.1.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i139.photobucket.com-11790-1377472264.2.jpg) |
76-914 |
Aug 26 2013, 10:58 AM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,657 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
It varies. This just establishes your ride height. Start at any position (maybe the 2nd) then lower the car move it a few feet, check your tire/fender clearance and general over height and adjust accordingly. (IMG:style_emoticons/default/beerchug.gif)
wndsnd |
Aug 26 2013, 11:06 AM
You wanted a horse, but got a goat. Nobody wants a goat.... Group: Members Posts: 2,861 Joined: 12-February 12 From: North Shore, MA Member No.: 14,124 Region Association: North East States |
It varies. This just establishes your ride height. Start at any position (maybe the 2nd) then lower the car move it a few feet, check your tire/fender clearance and general over height and adjust accordingly. (IMG:style_emoticons/default/beerchug.gif) There is no drive train in the car yet so final adjustments can't be made. I was looking for a startiing point. I think I will just leave the rings where they are for now, and adjust once I get an engine in the car. (IMG:style_emoticons/default/beerchug.gif) |
Lo-Fi Version | Time is now: 19th January 2025 - 02:19 AM |
