mig questions, sample pics added |
jimkelly |
Aug 21 2013, 10:29 AM
Delaware USA Group: Members Posts: 4,969 Joined: 5-August 04 From: Delaware, USA Member No.: 2,460 Region Association: MidAtlantic Region |
my original argon valve was bent up and leaked, so I ordered a new one. it had again, different sized threads, jeez.
so I went to ace ( r towel advice) and went with barbed fitting at both ends since the new argon valve came with a 1/4 barb already. question - when you are done welding and want to purge the lines of argon, after shutting the valve on the tank, do you have to waste wire or is there a way to purge without wasting wire? also, I expected the bead to stay at 15 psi when i turned the brass valve open, but it only rises to 15 psi or what ever I set it at, when I pull the red trigger on the mig - is this normal? also - I prepped some of my old real estate signs for practice : ) jim Attached image(s) |
scotty b |
Aug 26 2013, 11:49 AM
rust free you say ? Group: Members Posts: 16,375 Joined: 7-January 05 From: richmond, Va. Member No.: 3,419 Region Association: None |
I've never used the grease, but supposedly it works. Buy a pair of welders pliers. They are shaped to fit inside the nozzle. A good scraping with those does the trick. it also gives you a wire cutter, and a good inside grip for removing hot or stuck nozzles / tips
you're going to need to cut your settings back a tad bit for the .025, but not much. Once you get comfortable with it, you can turn the heat back up and get a better " melt in " when tacking one spot to another. Attached image(s) |
Lo-Fi Version | Time is now: 28th September 2024 - 02:31 AM |
