mig questions, sample pics added |
jimkelly |
Aug 21 2013, 10:29 AM
Delaware USA Group: Members Posts: 4,969 Joined: 5-August 04 From: Delaware, USA Member No.: 2,460 Region Association: MidAtlantic Region |
my original argon valve was bent up and leaked, so I ordered a new one. it had again, different sized threads, jeez.
so I went to ace ( r towel advice) and went with barbed fitting at both ends since the new argon valve came with a 1/4 barb already. question - when you are done welding and want to purge the lines of argon, after shutting the valve on the tank, do you have to waste wire or is there a way to purge without wasting wire? also, I expected the bead to stay at 15 psi when i turned the brass valve open, but it only rises to 15 psi or what ever I set it at, when I pull the red trigger on the mig - is this normal? also - I prepped some of my old real estate signs for practice : ) jim Attached image(s) |
76-914 |
Aug 27 2013, 08:55 AM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,519 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
The dip gel stuff works. I don't know if this is Snake Oil but last trip to the welding supply I bought these felt disc's that slide over the wire before the feeder that are supposed to lub and clean the wire. We shall see.
Lo-Fi Version | Time is now: 27th June 2024 - 08:56 AM |
