Rear spring shock install question, what have I done wrong? |
Type 47 |
Aug 25 2013, 05:11 PM
Senior Member Group: Members Posts: 788 Joined: 1-June 10 From: St. Louis, MO Member No.: 11,790 Region Association: None |
Installing new Bilstein shocks with 140 lb springs. took off stock springs with Koni's with a spring compressor. I didn't really need the spring compressors for the Bilstein's and now they slip off the bottom cradle. The Bilstein cradle is flat where the Koni's is more formed, like the top piece from the car.
What am I doing wrong here (note I installed them backwards to see it there was a difference). which reminds me...which end is up the small coils or the larger? (IMG:http://www.914world.com/bbs2/uploads_offsite/i139.photobucket.com-11790-1377472264.1.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i139.photobucket.com-11790-1377472264.2.jpg) |
r_towle |
Aug 27 2013, 01:10 PM
Custom Member Group: Members Posts: 24,704 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
bottom (IMG:style_emoticons/default/smile.gif)
I like it low. Honestly, 2-4th from the bottom... really depends on what you like. the lower you go, the cooler it will look, just saying. rich |
wndsnd |
Aug 27 2013, 01:52 PM
You wanted a horse, but got a goat. Nobody wants a goat.... Group: Members Posts: 2,861 Joined: 12-February 12 From: North Shore, MA Member No.: 14,124 Region Association: North East States |
bottom (IMG:style_emoticons/default/smile.gif) I like it low. Honestly, 2-4th from the bottom... really depends on what you like. the lower you go, the cooler it will look, just saying. rich Thanks rich, I moved up to the 4th groove because I am concerned with tire clearance .The tires/rims I bought off the net and did not come with the car. The fenders are not rolled but the hell hole side had much work. I will adjust once I get a powertrain in the car. |
Lo-Fi Version | Time is now: 19th January 2025 - 02:20 AM |
