Rear spring shock install question, what have I done wrong? |
Type 47 |
Aug 25 2013, 05:11 PM
Senior Member Group: Members Posts: 788 Joined: 1-June 10 From: St. Louis, MO Member No.: 11,790 Region Association: None |
Installing new Bilstein shocks with 140 lb springs. took off stock springs with Koni's with a spring compressor. I didn't really need the spring compressors for the Bilstein's and now they slip off the bottom cradle. The Bilstein cradle is flat where the Koni's is more formed, like the top piece from the car.
What am I doing wrong here (note I installed them backwards to see it there was a difference). which reminds me...which end is up the small coils or the larger? (IMG:http://www.914world.com/bbs2/uploads_offsite/i139.photobucket.com-11790-1377472264.1.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i139.photobucket.com-11790-1377472264.2.jpg) |
76-914 |
Aug 25 2013, 05:41 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,657 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
Here is your exact setup. (IMG:style_emoticons/default/agree.gif) Once it's down and your not going neg G not a problem. Otherwise zip tie it on the top. You'll need to select a ride height on those. If you've got a 6 try the 4th perch. (IMG:style_emoticons/default/beerchug.gif)
martinef1963 |
Aug 27 2013, 06:32 PM
The Saga Continues... Group: Members Posts: 320 Joined: 9-November 04 From: Miami, FL, USA Member No.: 3,080 Region Association: South East States |
Here is your exact setup. (IMG:style_emoticons/default/agree.gif) Once it's down and your not going neg G not a problem. Otherwise zip tie it on the top. You'll need to select a ride height on those. If you've got a 6 try the 4th perch. (IMG:style_emoticons/default/beerchug.gif) Why would you zip tie on the top? I've read on the forum of this procedure, but really have not read "why?" I too have the same set up as this post. Knowledge is power, or like someone once told me knowledge is "potential" power. thanks, Fern |
Lo-Fi Version | Time is now: 19th January 2025 - 02:22 AM |
