> Rear spring shock install question, what have I done wrong?
Type 47
post Aug 25 2013, 05:11 PM
Installing new Bilstein shocks with 140 lb springs. took off stock springs with Koni's with a spring compressor. I didn't really need the spring compressors for the Bilstein's and now they slip off the bottom cradle. The Bilstein cradle is flat where the Koni's is more formed, like the top piece from the car.
What am I doing wrong here (note I installed them backwards to see it there was a difference). which reminds me...which end is up the small coils or the larger?
(IMG:http://www.914world.com/bbs2/uploads_offsite/i139.photobucket.com-11790-1377472264.1.jpg)
(IMG:http://www.914world.com/bbs2/uploads_offsite/i139.photobucket.com-11790-1377472264.2.jpg)
wndsnd
post Aug 27 2013, 03:18 PM
You wanted a horse, but got a goat. Nobody wants a goat....
Finished.
Thanks everyone.
Really sorry Type 47 that I high-jacked this thread, but thanks for bringing this to my attention! I hope you have yours sorted out. (IMG:style_emoticons/default/bye1.gif)
r_towle
post Aug 27 2013, 09:07 PM
Custom Member
QUOTE(wndsnd @ Aug 27 2013, 05:18 PM) *
Finished.
Thanks everyone.
Wndsnd, you DO NOT have progressive coils.
You also won't need to zip tie your coils to the top if you needed a spring compressor to install them.
Is only required if the springs are loose when the upper nut it tight.
Rich
Type 47   Rear spring shock install question   Aug 25 2013, 05:11 PM
jimkelly   that silver plate is upside down - I think   Aug 25 2013, 05:19 PM
messix   that silver plate is upside down - I think Yup l...   Aug 25 2013, 05:24 PM
76-914   Here is your exact setup. :agree: Once it's d...   Aug 25 2013, 05:41 PM
martinef1963   Here is your exact setup. :agree: Once it's ...   Aug 27 2013, 06:32 PM
Type 47   Thanks guys :headbang: I will filp the plate ove...   Aug 25 2013, 06:12 PM
messix   there should be a spilt ring [a wire that almost g...   Aug 25 2013, 07:55 PM
wndsnd   Your telling me these are upside down? Sorry ...   Aug 25 2013, 08:44 PM
messix   Your telling me these are upside down? Sorry...   Aug 25 2013, 08:47 PM
wndsnd   Your telling me these are upside down? Sorr...   Aug 25 2013, 09:00 PM
Type 47   Your telling me these are upside down? Sorry...   Aug 25 2013, 08:57 PM
zambezi   Another reason the silver perch should be the othe...   Aug 25 2013, 08:52 PM
r_towle   Upside down guys. The clip won't car, but the...   Aug 25 2013, 08:56 PM
wndsnd   Upside down guys. The clip won't car, but th...   Aug 26 2013, 10:23 AM
wndsnd   OK I flipped the plates. Where would you rec...   Aug 26 2013, 08:43 AM
zambezi   The lower the clip the lower the ride height. I s...   Aug 26 2013, 08:58 AM
76-914   It varies. This just establishes your ride height....   Aug 26 2013, 10:58 AM
wndsnd   It varies. This just establishes your ride height...   Aug 26 2013, 11:06 AM
wndsnd   :bump: Rich T, Racer Chris, Anyone? Where wou...   Aug 27 2013, 06:38 AM
Racer Chris   Start at the 4th groove from the bottom John. You ...   Aug 27 2013, 07:18 AM
wndsnd   Start at the 4th groove from the bottom John. You...   Aug 27 2013, 07:42 AM
r_towle   bottom :) I like it low. Honestly, 2-4th from the...   Aug 27 2013, 01:10 PM
wndsnd   bottom :) I like it low. Honestly, 2-4th from th...   Aug 27 2013, 01:52 PM
wndsnd   Finished. Thanks everyone. Really sorry Type 47 ...   Aug 27 2013, 03:18 PM
Type 47   Finished. Thanks everyone. Really sorry Type 47...   Aug 27 2013, 05:53 PM
r_towle   Finished. Thanks everyone. Really sorry Type 47...   Aug 27 2013, 09:07 PM
wndsnd   Finished. Thanks everyone. Really sorry Type 4...   Aug 28 2013, 06:19 AM
r_towle   [quote name='r_towle' post='1916319' date='Aug 27...   Aug 28 2013, 06:49 AM
Type 47   so from the pictures the large coils are bottom an...   Aug 27 2013, 06:14 PM
wndsnd   so from the pictures the large coils are bottom a...   Aug 27 2013, 06:40 PM
messix   [quote name='Type 47' post='1916202' date='Aug 27...   Aug 27 2013, 07:17 PM
r_towle   I don't think he has progressive springs, so I...   Aug 27 2013, 06:18 PM
Type 47   I don't think he has progressive springs, so ...   Aug 27 2013, 06:43 PM
messix   [quote name='r_towle' post='1916209' date='Aug 27...   Aug 27 2013, 07:16 PM
r_towle   [quote name='r_towle' post='1916209' date='Aug 2...   Aug 27 2013, 09:05 PM
messix   it doesn't really matter. and no need to tie ...   Aug 27 2013, 06:55 PM
r_towle   You are fine, they are not progressive. If you ar...   Aug 27 2013, 07:04 PM
martinef1963   You are fine, they are not progressive. If you a...   Aug 27 2013, 07:35 PM
wndsnd   You are fine, they are not progressive. If you a...   Aug 27 2013, 07:48 PM
brant   too low gives you terrible suspension travel too l...   Aug 27 2013, 09:33 PM
10 User(s) are reading this topic (10 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 19th January 2025 - 02:15 AM
