Saphire Radio Wiring, Got a couple of questions |
jim_hoyland |
Aug 29 2013, 06:08 PM
Get that VIN ? Group: Members Posts: 9,419 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
Got this vintage Saphire radion and want to wire it to each side speaker; it was originally wired to just one speaker.
I'm thinking that spliting each of the two wires will do the trick ? If not I'd like to know. And, can this radio be wired to an amp ? Attached image(s) |
CptTripps |
Aug 30 2013, 06:58 AM
:: Punch and Pie :: Group: Members Posts: 3,584 Joined: 26-December 04 From: Mentor, OH Member No.: 3,342 Region Association: Upper MidWest |
Always measure the speaker, without anything connected to it.
You're measuring the resistance of the voice coil. Try it at the terminals on the speaker, and if you can reach it without damaging the speaker, touch the leads from the coil too. (usually on the back of the terminal.) This will also tell you what kind of resistance the terminal is adding, and give you a more accurate reading on the speaker. Although in this circumstance, you're trying to match the current resistance, so measuring the terminal is the best way to replicate what you have. |
Lo-Fi Version | Time is now: 28th September 2024 - 03:44 PM |
