chad newton |
Member ![]() ![]() Group: Members Posts: 110 Joined: 26-August 11 From: behind the red curtain Member No.: 13,491 Region Association: None ![]() |
What is the difference between 110 and 108 stub axles and transmission stubs? Educate me guys. One us us has some parts for me but says they are 110mm 4 bolts 2 pins.
r_towle |
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,599 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States ![]() ![]() |
2mm
chad newton |
ChrisFoley |
I am Tangerine Racing ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,937 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None ![]() ![]() |
2mm Hah, I just don't want to buy stuff that will not work. Did any porsche come with 110 stub axles and axle shafts. Chad, I think that 108mm 911 cvs have six 8mm bolts and the 110 mm 911 cvs have four 10mm bolts + pins. The associated stub axles and trans output flanges can't be mix matched. |
chad newton |
2mm Hah, I just don't want to buy stuff that will not work. Did any porsche come with 110 stub axles and axle shafts. Chad, I think that 108mm 911 cvs have six 8mm bolts and the 110 mm 911 cvs have four 10mm bolts + pins. The associated stub axles and trans output flanges can't be mix matched. Ok, so if I have 110 stubs and out put shafts theoretically everything could be converted over right? What about hubs and bearings do they stay the same then. |
Lo-Fi Version | Time is now: 29th June 2024 - 04:50 AM |
