BS Chairman |
Member ![]() ![]() Group: Members Posts: 98 Joined: 27-December 02 From: Southeast Michigan Member No.: 28 ![]() |
FS misc 914 parts - Revised prices
Newest Items Late Dash - VGC has one delaminiation at the corner of the left side gauge pod - $250 See Below Rocker Panels - See Below Windsheild gasket- See Below Blasted and painted trailing arms w/hubs- See Below Many newer items listed below. 1.8 FI computer $25 was running when switched to carbs L&R A Pillar cover w/plugs $25 Splash pan for under car. Blasted, painted, has some pits, tabs good $50 Door switch with gasket $5 Center/3rd Seat - Plastic tray decent, cracked hole. Center pad is solid, vinyl good $55 Early gauge set with silver buttons. Trip ODO unknown. $100 Headlight Motor Covers (pair) $20 no cracks Hood cable and pull - chipped paint - no key = $5 Ignition cylinder lock w/key we think it's late 71-73 - $5 Side marker Lens, crack on top - free with other purchase Side Targa Strip, the ones on the top, not the rear strips - so/so condition $5 Defroster vents -later cars w/center defrost $10 Will give discount for multiple items All items are plus shipping I take PayPal Attached image(s) ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() |
BS Chairman |
Rubber Seal never used $150
This is the seal at the top of the windshield with corner blocks to the section that seal at the front of the triabgle door glass. Rear Trailing arms, 4 bolt Hubs and bearing Caps. Done in 2 part epoxy paint. $150 Pair of rear wheel bearings $160 Attached image(s) ![]() ![]() ![]() ![]() |
Lo-Fi Version | Time is now: 25th June 2024 - 11:33 PM |
