> 5-lug conversiosn-looking for advice, Putting on the PMB group buy 5 lug hub conversion
DRPHIL914
post Sep 9 2013, 08:42 AM
Dr. Phil
I am finally getting around to doing this, i am wondering who else has done this and whether you have any words of wisdom, etc.
One thing to know, I have newly re-done trailing arms, with the new hubs and bearings already installed, also new pivot shafts and bushings as well -
this week i was able to order my newly reman. calipers from PMB, so "while i am at it" is the catch phrase to use here i think, i also had them send me new brake hoses and master cylinder(mine just went bad, so i have not been able to drive the car).
So i have not seen anyone else that did this group buy post any thread or pictures on this process, so i figured i would do this when i get started, but would appreciate the advice! I have done brakes on many other vehicles but not my 914
here is what i already have done -
-new shocks and springs- rear: sport bilistein's with 100#springs, new factory anti-roll bar bushings.
thanks Eric and Bill H. for getting the group buy put together, and Eric for the ONE-STOP-SHOP and providing all the necessary components!!!!.
Phil
Luke M
post Sep 9 2013, 09:33 AM
Hi Phil,
How's things?
This is pretty straight forward as far as install goes.
Go to Eric's website and look at his videos on the install.
You may need to find some threaded rod and some large washers to install the hubs.
Otherwise easy to do.
Take care,
DRPHIL914
post Sep 9 2013, 12:59 PM
Dr. Phil
QUOTE(Luke M @ Sep 9 2013, 11:33 AM) *
Hi Phil,
How's things?
Take care,
Luke,
going good, been finishing a bathroom remodel, so next week i should be on top of this, getting ready to order tires, the calipers from eric came saturday, and new MC came today. so i almost set. I had the rear hubs and bearings installed into newly finished rear trailing arms by Eric, also new bushings and pivot shaft so that should be pretty easy. I will take a look at the Video, and Eric just sent me a link to his thread on setting the venting/clearance.
How's your six conversion going? did you put the new rims on yet? I have been doing a little self polishing on the outer rims, seem to be cleaning up nicely. I will post a pic once i paint the pedals!.
Phil
Philip W.   5-lug conversiosn-looking for advice   Sep 9 2013, 08:42 AM
Luke M   Hi Phil, How's things? This is pretty straigh...   Sep 9 2013, 09:33 AM
Philip W.   Hi Phil, How's things? This is pretty straig...   Sep 9 2013, 12:59 PM
lsintampa   If you use stock rear calipers, you are going to h...   Sep 9 2013, 01:20 PM
Jeffs9146   :agree: Just to be clear it is 2mm off the di...   Sep 9 2013, 01:26 PM
Philip W.   :agree: Just to be clear it is 2mm off the d...   Sep 9 2013, 01:55 PM
Eric_Shea   Ummmmmmmmmmm... Les bought 914-6 rear rotors. Th...   Sep 9 2013, 02:18 PM
Jeffs9146   Ummmmmmmmmmm... Les bought 914-6 rear rotors. T...   Sep 9 2013, 02:28 PM
lsintampa   Ummmmmmmmmmm... Les bought 914-6 rear rotors. T...   Sep 9 2013, 03:02 PM
Chris H.   Ummmmmmmmmmm... Les bought 914-6 rear rotors. T...   Sep 10 2013, 09:27 AM
lsintampa   [quote name='Eric_Shea' post='1923392' date='Sep ...   Sep 10 2013, 09:34 AM
Eric_Shea   Kinda aware of all that. 914-6 rotors need to be ...   Sep 9 2013, 02:53 PM
Eric_Shea   Oh, I forgot to add these !!!   Sep 9 2013, 02:53 PM
Chris H.   Got it. The rotors in the group buy were redrille...   Sep 10 2013, 10:02 AM
Eric_Shea   Some Further Edification: There's a couple wa...   Sep 10 2013, 12:08 PM
Philip W.   Eric, thanks for all this info. for once it seam...   Sep 10 2013, 12:27 PM
bigkensteele   Some Further Edification: ... If you are using st...   Sep 10 2013, 07:53 PM
Jeffs9146   Just have the rotors milled 2mm! If you don...   Sep 10 2013, 07:57 PM
bigkensteele   Just have the rotors milled 2mm! If you don...   Sep 10 2013, 08:05 PM
Jeffs9146   Just have the rotors milled 2mm! If you don...   Sep 10 2013, 08:16 PM
Eric_Shea   Just have the rotors milled 2mm! If you don...   Sep 10 2013, 09:22 PM
- Lo-Fi Version Time is now: 6th January 2025 - 06:08 PM
