Engine Seems To Run Hot, Even on cool days |
Mblizzard |
Sep 15 2013, 04:18 PM
Advanced Member Group: Members Posts: 3,033 Joined: 28-January 13 From: Knoxville Tn Member No.: 15,438 Region Association: South East States |
Ok so I have been driving my new 2056 with dual webers an a SVDA dizzy with electronic ignition. Timing is set at 30 btdc. It seems like when I am on the interstate the temp gauge seems to ride at about 75% of the way toward hot.
The flaps should be set correctly and the thermostat seems to be allowing the flaps to move completely. As it moves toward hot I notice a lot of pinging. Plugs don't seem to be running hot or lean by looking at them. I am going to look at the flaps with my scope to verify the position but what to check after that? |
rhodyguy |
Sep 16 2013, 09:41 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,116 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
mike, have you verified that the cooling flaps are indeed fully opening when at temp?
k |
Mblizzard |
Sep 16 2013, 12:45 PM
mike, have you verified that the cooling flaps are indeed fully opening when at temp? k Kevin, I did that and they seemed to be fully open when the thermostat was fully expanded. I removed the cable and verified movement and just left it off but still had high temps. |
Lo-Fi Version | Time is now: 26th June 2024 - 12:10 AM |
