15" or 16" Fuchs, Decided......going with the 16" |
JStroud |
Sep 19 2013, 08:02 AM
Senior Member Group: Members Posts: 1,463 Joined: 15-January 11 From: Galt, California Member No.: 12,594 Region Association: Northern California |
I want to get another set of wheels for the white car, the 14" Fuchs are too limited on tire selection, plus too high RPM at freeway speeds, odometers off and so on.
Now the desicion, I've been offered a set of 16 x 7 Fuchs, but through my research if I understand right I would need just the right size tire then still have to pull the back fender a little to make them fit......if thats true, not sure I want to do that. (Narrow body car) Then yesterday I came across a set of 15 x 6 Fuchs, both sets are in very good condition and about the same price. Haven't done much research on 15" wheels, only have my iPhone this week, limited search ability. So what do the experts say, which will fix my issues better, 15" or 16".....and fit my car the best. Thanks Jeff |
pcar916 |
Sep 19 2013, 08:28 AM
Is that a Lola? Group: Members Posts: 1,523 Joined: 2-June 05 From: Little Rock, AR Member No.: 4,188 Region Association: None |
(IMG:style_emoticons/default/agree.gif) about tire selection. Also, the larger wheels will need a lower aspect ratio tire to keep the speedo in the same accuracy range. (Null if you use GPS as your speedo)
Make sure whichever of these you get that the offset is right for your car. If that doesn't eliminate one of them then get whichever makes you happy. Good luck |
JStroud |
Sep 19 2013, 08:34 AM
Make sure whichever of these you get that the offset is right for your car. Good luck Ok now I'm going to show my lack of knowledge in this area....how do I determine the offset for my car, or is this a set measurement for all 914s...and how do you determine the offset for a wheel. Thanks Jeff |
pcar916 |
Sep 19 2013, 11:40 AM
... how do I determine the offset for my car, ... and how do you determine the offset for a wheel. Here's a link to a page with lots of technical wheel stuff including offset, which is measured from the center-line of the wheel. With this you can make your own measurements, including your stock 914 wheels. However, if you are putting wider rims on the car the offset for the front, or the back, or both won't necessarily be the same. https://www.rsracing.com/tech-wheel.html My car is a conversion so I don't know offhand what the offset of a stock car is and I can't get to the factory manuals quickly. Someone here will know. BBS and Fuchs wheels I have use different spacers to get them to the correct placement in the wheelwells. Since 1994 I've put on the wrong spacers a couple of times. It's immediately apparent when the tire rubs either the inside of the wheelwells, or the fenders/front spoiler. |
Lo-Fi Version | Time is now: 26th September 2024 - 05:24 PM |
