> V8 tranny thoughts
Brett W
post Jul 16 2004, 08:41 PM
Why no just take a standard 915-930 tranny and flip it up side down? This should take the hassels out of flipping the ring gear, you would have to come up with pump and a shift linkage though?
andys
post Jul 21 2004, 10:10 AM
With the Audi model 016 gearbox, you will not be able to swap out the right parts from a 951 to get the good ratio's and strengthened parts. The input shaft and first gear are a one piece design, so you're forced to stay with the Audi 1st (3.60:1) which means you don't get the heat treated 951 1st (3.50:1). The 2nd thru 5th ratio's are very close to the same, so no need to swap there. The R&P ratio is where you gain the advantage with the taller geared 951. Though un-substantiated, apparently the differential carrier bearings are larger on the 951 than on the Audi, so they will not swap.......I recalll reading that the 951 racers swap out the R&P for a NA 944 R&P to get a lower ratio, so perhaps there's a chance for interchangeability (Any 951 experts or racers out there that can verify this?). For the cost, I would think it easiest to simply stay with the Audi 016, though the net 5th gear ratio is about the same a a stock 901. Audi 016 model 3U is the only one that has a taller 5th, but was only available in Europe. Good luck.
Andy
Brett W   V8 tranny thoughts   Jul 16 2004, 08:41 PM
skline   I dont know enough about it yet but I am looking i...   Jul 17 2004, 07:20 AM
Mueller   Brad has or had an adaptor plate for running an up...   Jul 17 2004, 07:58 AM
Brett W   I want the baddest street car known to man yet I h...   Jul 17 2004, 06:39 PM
dan10101   While we're talking about V8 trannies. how abo...   Jul 17 2004, 08:51 PM
LS6/914   Installed a 915 in place of a 901 in a clients v8 ...   Jul 18 2004, 09:07 AM
BIGKAT_83   <...   Jul 18 2004, 05:34 PM
Brett W   Please post the pics. I would like to see them. ...   Jul 18 2004, 10:08 PM
LS6/914   LS2 ? At GM we had a LS1 and LS6. We had LT1, LT4...   Jul 18 2004, 10:25 PM
dan10101   Oh please, can you tell me where to get info on th...   Jul 18 2004, 10:31 PM
LS6/914   Your local Chevy or speed shop should have the Che...   Jul 18 2004, 10:46 PM
dan10101   I'm just looking for general info. Like what ...   Jul 18 2004, 11:36 PM
Scott Carlberg   ...   Jul 19 2004, 12:12 AM
Brett W   The LS2 is the new version of the LS1. 415 hp, 15...   Jul 19 2004, 05:58 AM
Mueller   Brett, Contact Ed Ducey (propicer), he is a partn...   Jul 19 2004, 09:58 AM
bondo   ...   Jul 19 2004, 10:43 AM
turbo914v8   Hi guys, super lurker turbo Paul here. I have not ...   Jul 19 2004, 07:56 PM
aircooledboy   So, what $ does a Pantera box go for???   Jul 19 2004, 07:59 PM
dan10101     Jul 19 2004, 08:16 PM
dan10101
  Jul 20 2004, 08:02 AM
turbo914v8   From what I have seen it’s a toss up between the...   Jul 20 2004, 07:15 PM
neo914-6   Here's more comparative info....Mid-Engine Tra...   Jul 20 2004, 10:19 PM
dan10101   Felix, Thanks for the links. After reading that...   Jul 20 2004, 11:06 PM
Otmar   <...   Jul 20 2004, 11:11 PM
neo914-6   Dan, Glad my late night web surfing helped someone...   Jul 20 2004, 11:47 PM
James Adams     Jul 21 2004, 06:23 AM
skline   Well if you guys are thinking of trying an Audi 50...   Jul 21 2004, 07:49 AM
andys   With the Audi model 016 gearbox, you will not be a...   Jul 21 2004, 10:10 AM
Otmar   Slightly OT here, Anyone know if you can flip the...   Jul 21 2004, 10:25 AM
13 User(s) are reading this topic (13 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 4th January 2025 - 07:31 PM
