martinef1963 |
The Saga Continues... ![]() ![]() Group: Members Posts: 320 Joined: 9-November 04 From: Miami, FL, USA Member No.: 3,080 Region Association: South East States ![]() |
Hello. Last week or so I chimed in on a thread about Bilstein's adjustable perch. The consensus was to start on the 3rd level from the bottom.
I did, however, the driver's side tire still rubbed on the quarter panel lip, however, did not on the passenger side (close, but still). Today I moved the perch up to the 5-tier and the tire is still rubbing on the lip - on the passenger side much better clearance. I did note that the driver's side wheel sits out further than the passenger side and all other wheels. I took a look at the CV joints to see if there was a difference between side, however, did not see anything that would make me think it would be the CV joints. I inspected the A-arm and it appears to be solid, no signs of rust or break(s). Can someone throw some ideas out at me. I drove this car out from California in 2002 / 2003 and didn't have this problem. I initially suspected the CV joints because when we did the rebuild the CV were removed and reinstalled. I will get some pictures so you guys can see exactly what I am talking about. thanks, Fern |
Spoke |
Jerry ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,994 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None ![]() ![]() |
Something doesn't look right there. That driver side tire is way out compared to the pass side.
Is the rear end in alignment? How much is the gap from the inside of the tire to the fender well on each side? |
martinef1963 |
Something doesn't look right there. That driver side tire is way out compared to the pass side. Is the rear end in alignment? How much is the gap from the inside of the tire to the fender well on each side? Prior to rebuilding the engine I had it aligned and it drove fine with respect to alignment / height. I can cup my fingers on the passenger side with no problem, about 1 1/2 to 2 inch clearance - can't get my finger in between the driver's side and on the 5th perch??? Fern |
Lo-Fi Version | Time is now: 26th June 2024 - 01:55 AM |
