martinef1963 |
The Saga Continues... ![]() ![]() Group: Members Posts: 320 Joined: 9-November 04 From: Miami, FL, USA Member No.: 3,080 Region Association: South East States ![]() |
Hello. Last week or so I chimed in on a thread about Bilstein's adjustable perch. The consensus was to start on the 3rd level from the bottom.
I did, however, the driver's side tire still rubbed on the quarter panel lip, however, did not on the passenger side (close, but still). Today I moved the perch up to the 5-tier and the tire is still rubbing on the lip - on the passenger side much better clearance. I did note that the driver's side wheel sits out further than the passenger side and all other wheels. I took a look at the CV joints to see if there was a difference between side, however, did not see anything that would make me think it would be the CV joints. I inspected the A-arm and it appears to be solid, no signs of rust or break(s). Can someone throw some ideas out at me. I drove this car out from California in 2002 / 2003 and didn't have this problem. I initially suspected the CV joints because when we did the rebuild the CV were removed and reinstalled. I will get some pictures so you guys can see exactly what I am talking about. thanks, Fern |
r_towle |
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,598 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States ![]() ![]() |
Would not be the cv joint, it would be the trailing arm and how it was mounted and adjusted.
Rich |
Lo-Fi Version | Time is now: 26th June 2024 - 02:16 AM |
