partwerks |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,593 Joined: 7-September 06 From: Grand Island, NE Member No.: 6,787 ![]() |
When I put on a new trans ground strap, it definitely made a difference in the starting, and I thought it got rid of the other strange cutting out bug as well?
For at least the last 4 months, it did not act up until this Friday, in about a 15 mile stretch on the Interstate at about 75 mph, it will cut out for about 6 or 7 seconds, and then oddly, take right off again. It did that 3 times. It only tends to do it when going about that speed, (or faster) 2004, WRX. 2.0 Also, I had the mechanic re balance the front tires to see if that was it, and again when going at least 70, it will make the steering wheel quiver. He looked at the front end on the hoist, but could not see anything obvious? It also does it off and on when going at that speed, and not constantly. Any thoughts, ideas, or suggestions on what could be causing it? |
partwerks |
Here's a couple tips that I had received, but what don't make sense, is that why would I go for so long, and not cut out, and had not touched the front end either, and now it wants to make the wheel quiver at a high rate of speed? What would make it cut out at higher speeds, but not lower? Same with the quivering? I have not hit any big, fat, potholes either!!
It might be fuel delivery, kinked hose, fuel filter, pump. Try it in 1 gear lower or up a long hill to see if it's worse. The wider wheels are always harder to balance on a 914. If the rim is spinning true, you'll probably need premium tires. |
Lo-Fi Version | Time is now: 26th June 2024 - 08:46 AM |
