Mike Sanford |
Newbie ![]() Group: Members Posts: 34 Joined: 15-September 12 From: Tucson, AZ Member No.: 14,935 Region Association: Southwest Region ![]() |
I'm a little above my skill set playing with this stuff.
Took the wife out yardsale-ing Saturday morning. This is Tucson, maybe 85 degrees at 8am. Drove two blocks from home, stopped at one. Drove another 5 blocks, car acted as if it ran out of gas. Gas tank is full. Key on, pulled fuel line off of rail and opened air flow meter, squirts fuel. Pulled injector out of a cylinder, moved air flow meter, no fuel. Shoved my analog voltmeter into injector plug, no sign of a signal at the injector. Played on the internet looking up l-jet trouble shooting, decided to start with checking the relay because it seemed less intimidating. From what I'm seeing there should be voltage between 88a, 88b, 88c, and 88z and 85 (the ground). I have voltage everywhere except 88c. Come back inside, back on the internet, 88c looks like it powers the auxilary air valve. Would this cause the whole system to shut down? Is there something else I should be checking? Thanks, Mike |
timothy_nd28 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,299 Joined: 25-September 07 From: IN Member No.: 8,154 Region Association: Upper MidWest ![]() ![]() |
How accurate are these readings? Are you still using the analog meter or is it digital?
Pin 88y is battery voltage on the dual relay. The test confirms that you do have the same voltage on that pin as you do on the battery. So far so good, but I don't like the voltage on pin 88d (9v). This shows you had a 2volt drop across the contact points inside the dual relay. If this is true, it's time for a new dual relay. |
Mike Sanford |
How accurate are these readings? Are you still using the analog meter or is it digital? Pin 88y is battery voltage on the dual relay. The test confirms that you do have the same voltage on that pin as you do on the battery. So far so good, but I don't like the voltage on pin 88d (9v). This shows you had a 2volt drop across the contact points inside the dual relay. If this is true, it's time for a new dual relay. This is a cheap analog meter. 11v is kind of a guess, I'm using the 10v scale and its a about that distance past the 10, not yet maxing out. Just checked 88d again, and (this time) 8v is exactly what its pointing to. I'll try to find my digital meter and double check my numbers. Real time cross country electrical trouble shooting, more help than I expected this morning, I'm grateful for your time. |
Lo-Fi Version | Time is now: 27th June 2024 - 09:05 PM |
