L-Jet: Over My Head, Bad ECU, car's back on the road. |
Mike Sanford |
Sep 23 2013, 10:03 AM
Newbie Group: Members Posts: 34 Joined: 15-September 12 From: Tucson, AZ Member No.: 14,935 Region Association: Southwest Region |
I'm a little above my skill set playing with this stuff.
Took the wife out yardsale-ing Saturday morning. This is Tucson, maybe 85 degrees at 8am. Drove two blocks from home, stopped at one. Drove another 5 blocks, car acted as if it ran out of gas. Gas tank is full. Key on, pulled fuel line off of rail and opened air flow meter, squirts fuel. Pulled injector out of a cylinder, moved air flow meter, no fuel. Shoved my analog voltmeter into injector plug, no sign of a signal at the injector. Played on the internet looking up l-jet trouble shooting, decided to start with checking the relay because it seemed less intimidating. From what I'm seeing there should be voltage between 88a, 88b, 88c, and 88z and 85 (the ground). I have voltage everywhere except 88c. Come back inside, back on the internet, 88c looks like it powers the auxilary air valve. Would this cause the whole system to shut down? Is there something else I should be checking? Thanks, Mike |
timothy_nd28 |
Sep 23 2013, 12:14 PM
Advanced Member Group: Members Posts: 2,299 Joined: 25-September 07 From: IN Member No.: 8,154 Region Association: Upper MidWest |
I identified a problem, but it maynot be the problem. With the jumper on and the fuel pump running 24-7 does the car run, or are we still in a no run mode? Also, do you have mechanical points or a pointless module?
Mike Sanford |
Sep 23 2013, 12:19 PM
I identified a problem, but it maynot be the problem. With the jumper on and the fuel pump running 24-7 does the car run, or are we still in a no run mode? Also, do you have mechanical points or a pointless module? With the jumper in place, we're still in a no run mode. Petronix instead of points. |
Lo-Fi Version | Time is now: 28th September 2024 - 07:44 AM |
