tornik550 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,248 Joined: 29-January 07 From: Ohio Member No.: 7,486 Region Association: None ![]() |
For the past year, I have been fighting my innovate lc1 setup. It would work under certain circumstances. I never really trusted the readings. Everything was setup properly and calibrated properly. I just got fed up and got an AEM setup. Installed it, started right up. Turns out that my innovate readings were really inaccurate. I was having a super difficult time tuning my carbs cause I was getting strange readings. Now with the AEM, it turns out that my carbs are pretty close to where they should be (IMG:style_emoticons/default/headbang.gif)
Very please with the AEM setup. |
Justinp71 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,588 Joined: 11-October 04 From: Sacramento, CA Member No.: 2,922 Region Association: None ![]() ![]() |
Its been a couple months, any updates?
I like the AEM unit and all the tuners seem to rave about it. I also really like the colored LED's so you can see your AFR without having to stare at the gauge while your flooring it! I think I'll be ordering one... |
tornik550 |
Its been a couple months, any updates? I like the AEM unit and all the tuners seem to rave about it. I also really like the colored LED's so you can see your AFR without having to stare at the gauge while your flooring it! I think I'll be ordering one... I have been using it for the past few months. I highly recommend it. The air fuel gauge is no longer something that I think about cause it works perfectly without any problems. BUY ONE!!! |
Lo-Fi Version | Time is now: 30th June 2024 - 11:54 PM |
