tornik550 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,248 Joined: 29-January 07 From: Ohio Member No.: 7,486 Region Association: None ![]() |
For the past year, I have been fighting my innovate lc1 setup. It would work under certain circumstances. I never really trusted the readings. Everything was setup properly and calibrated properly. I just got fed up and got an AEM setup. Installed it, started right up. Turns out that my innovate readings were really inaccurate. I was having a super difficult time tuning my carbs cause I was getting strange readings. Now with the AEM, it turns out that my carbs are pretty close to where they should be (IMG:style_emoticons/default/headbang.gif)
Very please with the AEM setup. |
Justinp71 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,588 Joined: 11-October 04 From: Sacramento, CA Member No.: 2,922 Region Association: None ![]() ![]() |
Is the AEM cable long enough? Sounds like everyone just runs it under the motor, into the cable tunnel and up the front firewall? Does anyone know if its long enough to do the drivers side pillar gauge pod?
tornik550 |
Is the AEM cable long enough? Sounds like everyone just runs it under the motor, into the cable tunnel and up the front firewall? Does anyone know if its long enough to do the drivers side pillar gauge pod? My o2 sender is mounted on the passenger side rear of the car, It goes through the tin, around the passenger side of the engine, through the firewall, through the tunnel then up to the center under the ashtray. I had a lot of extra wire. I think you could reach a pillar however it is ok to splice extra wire in if needed. |
Lo-Fi Version | Time is now: 26th June 2024 - 12:18 AM |
