tweet |
Member ![]() ![]() Group: Members Posts: 200 Joined: 25-February 13 From: South Florida Member No.: 15,579 Region Association: South East States ![]() |
So my other topic is not getting any response, let me try a different approach. I know the guys, who know, are out there. This is a 96mm p & c combo that came out of my 1911cc. These are old school. I know for a fact that this engine was modified at least 20 years ago (the car has been stored that long). I have never been able to find part numbers or marks other than the "TS" inside the pistons. The cylinders have 18 fins, don't know, if that helps, with 24mm wrist pins. What I would like to know is if they are usable / worth salvaging for the rebuild? I'm on a budget. Car needs extensive fire damage repair.
As you can see, this piston suffered from some corrosion and has pitting. I am aware that there are engine parts that can be welded/metal deposited where there is pitting. Question is, is this piston repairable and at what cost? I also need two 96mm jugs to replace two that are also pitted (easy part) . TIA for the advice. -Dan Attached thumbnail(s) ![]() ![]() ![]() |
JoeSharp |
In Irvine, Ca. May 15-18 ![]() ![]() ![]() ![]() Group: Members Posts: 3,947 Joined: 9-July 03 From: DeLand, Florida Member No.: 898 Region Association: South East States ![]() |
Tweet: I'm in DeLand and we can do the honing right here and find out what size rings you need and all it will cost you is the fuel to drive up here and back. You can probably get the rings at Fisher on the way home.
Lo-Fi Version | Time is now: 26th June 2024 - 03:17 AM |
