> Signal Single Orange 74 EG33 Swap, Gone but not forgotten
914forme
post Sep 25 2013, 07:47 PM
Okay this is the car in all its glory ugly as heck, but hey its an auto-x car. (IMG:style_emoticons/default/new_shocked.gif) This one is from my first season of auto-x with this car.
Heres what it looks like today. Made it even uglier (IMG:style_emoticons/default/barf.gif)
Here is the goal, I can sketch ideas, but I can not draw at the level of others on this forum. Thank you 914 Visulizer. and my black pen. Now if I could find a good front view. And the flares are not on the car since I'm not using GT Flares.
But you get the general idea.
914forme
post Sep 29 2013, 08:22 PM
Only got a work a little Saterday, and maybe an hour today, my heart just wasn't in it, after the rainy Cincinnati Show. (IMG:style_emoticons/default/sad.gif)
I did get items pulled from my trans, and re-installed.
Tools needed.
12mm socket
14mm socket
27mm socket
Socket Wrench, or impact wrench for disassembly
Torque wrench for assembly
Punch
Big Hammer
Big Dead Blow Hammer with a Soft Face
Couple items to pry with
Cold Chisel
Small pick
Something to clean gasket material off with.
Two items to lock the drive shafts or flanges in place. I used to pipe wrenches.
Tube of Yamahabond or Hondabond
Oil dry see next item. (IMG:style_emoticons/default/sad.gif)
First make sure all the Tranny fluid is drained out of the trans. Or else you get a slick the size of the Exon Valdez spill.
Pull the bits and pieces not needed for the shifter. Its a roll pin, drive it out with a punch and a BFH. (IMG:style_emoticons/default/smash.gif) Watch pin fly across garage, you my want to save these pieces I'm going to modify (IMG:style_emoticons/default/sawzall-smiley.gif) (IMG:style_emoticons/default/welder.gif) (IMG:style_emoticons/default/smash.gif) them for the basis of my cable shifter.
It should look like this.
Remove all the bolts holding the nose onto the tranny. Put these aside for cleanup and re-use if your cover will allow, or measure them up for some new shinny ones.
Next pick up your Dead Blow or suitable alternative, and give it a few good whacks to loosen the adhesive, and hopefully open it up enough to get a nice wide pry in there with out damaging the mating surface. Once done heres the guts you get to pull out.
Next you pull these out. Grab ahold of both and lift they come out together. And you are left with this.
Pieces removed
Next up you have to get this nut off the shaft. It is a 27mm and is peened over. Mine was done in 4 spots. Some assembly line worker in Japan, did his job with vigor. (IMG:style_emoticons/default/smilie_pokal.gif) Out comes the punch and BFH, and undo all his hard work. Next I took my impact wrench and locked the axles and zipped it off.
This is the first set of items you will pull, nut and 2 washers.
Next slip the shaft sleeve off the shaft. for lack of better terminology. There will also be a stack of washers, hardened bearing surfaces, and a roller bearing. A pick is helpful here to get these all off the shaft.
The last one gave me fits but it has to come out or else the spool will not fit correctly This picture shows its not fully seated.
Next you will have to fiddle a little turning the shafts to get them lined up to get the spool to lock both inner and outer shafts together. And then with some luck it will drop into position.
Next add the washer that was next to the nut on your gear stack. Thread it on, then torque it down, to ??? I forgot its in the FSM for the WRX sorry. Don't forget to lock the shafts again. Easy enough.
Peen over the nut to lock it into place. You can use a punch, I found a cold chisel did the job with one whack per indent. Yes I followed the original assemblers lead and and did it four times.
Next up get rid of the factory sealant left on the mating surface. I stuffed the inside with paper towels, and started to clean it up with a angled die grinder and a scotch brite pad. done. Clean up with what ever harsh chemicals you have around for that purpose. (IMG:style_emoticons/default/dry.gif)
All that is left is seal the end with a thin bead of sealant, and place your cover on, torque down the cover. I have not gone there as I will be taking the trans apart further after cleaning up the outside.
This is the basics on how to convert to FWD transaxle for a 914 or other mid-engine car.
When you add it into the car, don't forget to add extra trans fluid to make up for the lack of central diff, and the other parts you removed.
914forme   Signal Single Orange 74 EG33 Swap   Sep 25 2013, 07:47 PM
914forme   History: After looking for 6 months I found this ...   Sep 25 2013, 07:47 PM
914forme   The Plan: Make this thing like Steve Austin. The...   Sep 25 2013, 07:48 PM
turk22   I like the plan, the visualizer is nice, orange an...   Sep 25 2013, 08:01 PM
914forme   This weekend I pulled the torsion bar adjuster off...   Sep 25 2013, 08:09 PM
914forme   The rears fair much better. As I already did flar...   Sep 25 2013, 08:21 PM
kg6dxn   You may want to get thinner front spacers to reduc...   Sep 25 2013, 08:29 PM
914forme   You may want to get thinner front spacers to redu...   Sep 25 2013, 08:38 PM
mepstein   Its an H33 from a Subaru SVX, that I have just pic...   Sep 25 2013, 08:42 PM
ConeDodger   You better have a whole bunch of power in that sco...   Sep 26 2013, 01:42 PM
Woody   You better have a whole bunch of power in that sc...   Sep 26 2013, 02:23 PM
914forme   I know y'alls hearts are in the right place, I...   Sep 26 2013, 05:05 PM
914forme   All the basic parts are in for the cable shifter. ...   Sep 26 2013, 05:15 PM
ConeDodger   Not just the heavy... It's the diameter. If yo...   Sep 26 2013, 05:32 PM
914forme   Not just the heavy... It's the diameter. If y...   Sep 26 2013, 08:25 PM
ConeDodger   Not just the heavy... It's the diameter. If ...   Sep 26 2013, 08:47 PM
914forme   And now for the rest of the good bits. The OBX ha...   Sep 26 2013, 05:38 PM
rick 918-S   Can you re-drill the centerlines? I did that to a ...   Sep 26 2013, 09:38 PM
914forme   Can you re-drill the centerlines? I did that to a...   Sep 27 2013, 06:59 AM
FourBlades   Nice build! :smash: Looking forward to see...   Sep 27 2013, 07:53 AM
914forme   Ha found wheel weights for 8.5"x15" Cent...   Sep 27 2013, 10:33 AM
914forme   Only got a work a little Saterday, and maybe an ho...   Sep 29 2013, 08:22 PM
914forme   Started working on the rotisserie. I should have ...   Sep 29 2013, 08:33 PM
914forme   Not much has happened over the last weekend. Life...   Oct 8 2013, 10:40 AM
Woody   You'll have a hard time finding a tire to run ...   Oct 8 2013, 12:24 PM
914forme   You'll have a hard time finding a tire to run...   Oct 8 2013, 12:34 PM
914forme   Okay things change in the world. Centerline-ish w...   Oct 31 2013, 03:21 PM
914forme   Gathering the parts to do a 108mm rear CV swap int...   Oct 31 2013, 03:36 PM
914forme   My how time moves :blink: Decided to get some p...   Apr 23 2014, 06:59 AM
Chris H.   How did I miss this one? Did you get that donor c...   Apr 23 2014, 09:36 AM
914forme   How did I miss this one? Did you get that donor ...   Apr 23 2014, 11:09 AM
Chris H.   Wow. Yeah that would have been terrible. I'l...   Apr 23 2014, 12:29 PM
914forme   Yeah I saw the Super charger unit looked neat. Si...   Apr 23 2014, 02:03 PM
914forme   Okay well now lets continue down the long path of ...   Apr 23 2014, 06:40 PM
gryphon68   Still have a long way to go. Rinse and Repeat 40...   Feb 16 2015, 10:30 AM
914forme   Still have a long way to go. Rinse and Repeat 4...   Feb 17 2015, 11:07 AM
914forme   And I started working on the rotisserie again. Ma...   Apr 23 2014, 06:57 PM
914forme   Okay Post Lady brought me these today. This is a ...   Apr 23 2014, 07:16 PM
Amenson   Wow, of all of the great details in your build thr...   Apr 24 2014, 10:59 AM
914forme   Wow, of all of the great details in your build th...   Apr 24 2014, 05:54 PM
Chris H.   When you put a flat piece of glass on the 924 gaug...   Apr 24 2014, 06:20 PM
914forme   When you put a flat piece of glass on the 924 gau...   Apr 24 2014, 06:44 PM
914forme   For todays update, I am tired of drilling holes fo...   Apr 24 2014, 06:37 PM
914forme   If I use this piece, I will need to redo the arche...   Apr 24 2014, 06:50 PM
Chris H.   Hey that's cool Stephen....great idea. I...   Apr 24 2014, 06:54 PM
914forme   Yeah, now that the word is out Chris, you might wa...   Apr 24 2014, 07:00 PM
914forme   Rotisseri has been complete :welder: I used a s...   May 20 2014, 07:14 PM
dan_the _body_guy   Rotisseri has been complete :welder: I used a ...   May 20 2014, 07:34 PM
914forme   A lot has happened since I updated this thread. S...   Feb 7 2015, 07:36 PM
mgp4591   Oh yeah... :popcorn:   Feb 8 2015, 07:05 AM
914forme   I was told today I need to start posting more in m...   Feb 12 2015, 05:08 PM
altitude411   Just get new ones from 914rubber... http://shop.91...   Feb 12 2015, 05:55 PM
914forme   So this weekend I got busy on engine mount, and tr...   Feb 17 2015, 11:23 AM
914forme   Now making my first bad design I wanted to use so ...   Feb 17 2015, 11:48 AM
914forme   Yesterday I got a set of wheels I have been waitin...   Feb 19 2015, 11:36 AM
914forme   spent the day finishing stripping the car. Doors ...   Feb 21 2015, 06:41 PM
Chris H.   Meant to post this...very pricey, but the Rocky Mo...   Feb 21 2015, 07:29 PM
914forme   Chris, Man them guys are expensive, and yes I have...   Feb 22 2015, 07:20 PM
mgp4591   Failed SD card is no excuse... still needs picture...   Feb 22 2015, 10:57 PM
Chris H.   Yeah re: the RMW intake...the part I don't get...   Feb 23 2015, 07:45 AM
914forme   Bad SD Card reader / cable. :angry: I tossed some...   Feb 23 2015, 07:57 AM
914forme   Its been cold around here -15 the other day, and I...   Feb 25 2015, 08:11 PM
914forme   Old man winter did not keep me out of the shop yes...   Mar 1 2015, 01:27 PM
914forme   Works been hell this last week, so time for some 9...   Mar 7 2015, 05:23 PM
Dave_Darling   I hope you marked the "rest" position of...   Mar 7 2015, 07:42 PM
914forme   I hope you marked the "rest" position o...   Mar 8 2015, 10:00 AM
914forme   My wife had a 1990 Miata, I added a bunch of goodi...   Jun 27 2015, 11:31 AM
Amenson   Stephen, I was reading your post and all I could t...   Jun 28 2015, 08:34 AM
Chris H.   Stephen...come back to the reservation... DON...   Jun 28 2015, 10:26 AM
914forme   Scott, not to worry I talked with my wife this mor...   Jun 28 2015, 05:40 PM
Amenson   Scott, not to worry I talked with my wife this mo...   Jun 28 2015, 07:04 PM
914forme   :sawzall: :smash: :sawzall: The none fun stuff....   Jul 20 2015, 04:18 PM
Amenson   :sawzall: :smash: :sawzall: The none fun stuff...   Jul 21 2015, 08:43 AM
914forme   Hmm, so I was reading the ForSale ad for the RS, s...   Jul 28 2015, 05:42 PM
76-914   :poke: About time that you got busy again. :stir:...   Jul 28 2015, 06:56 PM
914forme   Not sure the guys name, I can't retrieve it cu...   Jul 28 2015, 07:37 PM
mepstein   I thought craig at camp914 had done the RS tail li...   Jul 28 2015, 08:31 PM
914forme   Place called AR Concepts seems to have done them, ...   Jul 29 2015, 05:41 PM
914forme   Got the wrecked Miata out of the shop, hoping the ...   Jul 31 2015, 06:18 PM
76-914   How close is your starter terminal to the chassis....   Jul 31 2015, 06:42 PM
914forme   Yes thank you, I think I tested that, but maybe I ...   Aug 1 2015, 04:35 AM
914forme   First of Miata sold, one less temptress in my life...   Aug 1 2015, 05:34 PM
Andyrew   An now for an idea, well two really. Pink id...   Aug 2 2015, 11:13 PM
914forme   Finished cutting and grinding all the engine shelf...   Aug 2 2015, 05:50 PM
Amenson   With all that cleared out of the way there is plen...   Aug 3 2015, 07:54 AM
Chris H.   With all that cleared out of the way there is ple...   Aug 12 2015, 09:29 PM
jd74914   Speaking of turbo'd EG33's...anyone seen ...   Aug 13 2015, 01:10 PM
914forme   [quote name='Chris H.' post='2222585' date='Aug 1...   Aug 13 2015, 07:13 PM
mgp4591   [quote name='Chris H.' post='2222585' date='Aug ...   Aug 13 2015, 08:52 PM
914forme   :agree: I have my plans still trying to figure o...   Aug 5 2015, 07:06 PM
914forme   Weekend and back into the shop, long slow process ...   Aug 10 2015, 06:28 AM
3d914   Templates are a good thing. I will be doing so...   Aug 15 2015, 10:49 AM
mepstein   Are you removing the engine bar motor mounts.   Aug 10 2015, 06:57 AM
914forme   Nope, using a Small Car Mount and an early -4 engi...   Aug 10 2015, 07:15 AM
mepstein   I'll be pretty happy with the stock eg33 - hp....   Aug 13 2015, 08:59 PM
mgp4591   I'll be pretty happy with the stock eg33 - hp...   Aug 13 2015, 10:29 PM
914forme   :agree: Big injectors come fairly easy, I all re...   Aug 14 2015, 03:14 AM
Chris H.   Wow Steve, I should just copy this last post of yo...   Aug 15 2015, 08:37 AM
914forme   Chris, not sure about the dual MAFs, unless you pu...   Aug 15 2015, 03:12 PM
914forme   Today's Progress: Finished Hell Hole Template...   Aug 15 2015, 07:22 PM
4 Pages V  1 2 3 > »
- Lo-Fi Version Time is now: 3rd April 2025 - 01:25 AM
