stefs914 |
Newbie ![]() Group: Members Posts: 32 Joined: 27-April 13 From: lincoln ne Member No.: 15,812 Region Association: Upper MidWest ![]() |
I finally got all my ignition parts in new battery wires plugs cap rotor condenser. Resealed the gas tank with the por-15 kit drained and clean all the old fuel lines changes oil and went to start it and its getting zero fuel to the carbs. I don't hear any electrical noise from the fuel punp when I turn the key to acc and I'm also not getting any juice to the plug at the top not unless my volt meter is broke.
So I guess my question is, is do I try and get new fuses and see if that changes anything? Trace the wires and try to find a short? Or buy either a replacement pump an aftermarket pump? Thanks in advance for any advice. |
SLITS |
"This Utah shit is HARSH!" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 13,602 Joined: 22-February 04 From: SoCal Mountains ... Member No.: 1,696 Region Association: None ![]() ![]() |
If it is the original wiring and you switched to carbs it won't run as it is controlled by the FI system.
You will have to wire it into switched direct power or jumper the relay between terminals 30 and 87 on the relay or relay board. |
Lo-Fi Version | Time is now: 26th June 2024 - 03:59 AM |
