lsintampa |
Senior Member ![]() ![]() ![]() Group: Members Posts: 520 Joined: 28-January 13 From: Tampa, FL Member No.: 15,441 Region Association: South East States ![]() |
I installed a electric magnet release on my trunk. Tested it and all was great. So I thought it would be working for a while - at least long enough until I put a secondary release in, but I was totally wrong.
So not only is the release not dis-engaging the lock, I was stupid enough to already mount the P O R S C H E reflector on the face. There is a small gap between the reflector and the trunk that I might be able to wiggle a coat hanger into, but I'm not sure a) if that will work, b) how to wiggle the coat hanger even if I get in into the lock hole, or c) is there a better way? So don't (IMG:style_emoticons/default/chair.gif) me, I'm already feeling like (IMG:style_emoticons/default/post-2-1117899824.gif) |
r_towle |
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,599 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States ![]() ![]() |
I had a friend who had the same setup of electronic latch and Porsche reflector.
He drilled a 1/8 hole in exactly the right place to stick a long allen wrench in there and push open the latch. You really could not see it at all, but it was a good idea for insurance to get in there when needed. I suspect if you are game, someone can get you some accurate measurement...then its just drill a hole, stick in a stiff piece if steel (not a coat hanger) and push. Allen wrench was one of the T handle long ones... Rich |
JamesM |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,935 Joined: 6-April 06 From: Kearns, UT Member No.: 5,834 Region Association: Intermountain Region ![]() |
I had a friend who had the same setup of electronic latch and Porsche reflector. He drilled a 1/8 hole in exactly the right place to stick a long allen wrench in there and push open the latch. You really could not see it at all, but it was a good idea for insurance to get in there when needed. I suspect if you are game, someone can get you some accurate measurement...then its just drill a hole, stick in a stiff piece if steel (not a coat hanger) and push. Allen wrench was one of the T handle long ones... Rich (IMG:style_emoticons/default/agree.gif) I have the same thing on mine, along with a thin steel rod on my keychain to open it. |
Lo-Fi Version | Time is now: 1st July 2024 - 04:37 AM |
