McMark |
EDIT: I know about tube-and-water setups. You can't drive with those. I'm building some different.
I've been pondering this project for awhile, and now I'm finally getting ready to start. Every time I synch carbs I think about how terrible and approximate the process is. What I'm going to try is using a small, programmable computer called an Arduino. There are add-ons called Shields to expand the functionality, and I'm using a LCD screen shield. I'm going to hook up 4 to 6 MAP sensors to the Arduino and output their readings on the screen. Using this tool, I'll be able to numerically evaluate the relative balance of the carb throats. One possible shortcoming is that the intake pulses may create fluctuating values that are difficult to interpret. Although, I have some ideas that may deal with this. Some sort of averaging could help. (IMG:style_emoticons/default/idea.gif) Here's what the Arduino looks like (this is the Uno version) (IMG:http://www.914world.com/bbs2/uploads_offsite/www.adafruit.com-419-1381898348.1.jpg) Here's the screen shield (IMG:http://www.914world.com/bbs2/uploads_offsite/www.adafruit.com-419-1381898349.2.jpg) Here's the MAP sensors I'm going to start with. (IMG:http://www.914world.com/bbs2/uploads_offsite/thumbs4.ebaystatic.com-419-1381898350.3.jpg) I'm also probably going to have to make some plates that will go between the carb and manifold with a vacuum port on it. This would be the easiest way to access manifold vacuum since I can't count on carbs to have vacuum ports. Oh, and this will also be useable while driving to evaluate dynamic synch. |
rick 918-S |
Hey nice rack! -Celette ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,509 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region ![]() ![]() ![]() |
Sound is how I used to tune my triple Holley's on my big block. I wonder if you can add a mic function with a oscilloscope type output to the screen as a veri-able. Ya, I have no clue what I'm purposing. (IMG:style_emoticons/default/screwy.gif) (IMG:style_emoticons/default/wacko.gif) (IMG:style_emoticons/default/blink.gif)
pcar916 |
Is that a Lola? ![]() ![]() ![]() Group: Members Posts: 1,523 Joined: 2-June 05 From: Little Rock, AR Member No.: 4,188 Region Association: None ![]() ![]() |
Sound is how I used to tune my triple Holley's on my big block. I wonder if you can add a mic function with a oscilloscope type output to the screen as a veri-able. Ya, I have no clue what I'm purposing. (IMG:style_emoticons/default/screwy.gif) (IMG:style_emoticons/default/wacko.gif) (IMG:style_emoticons/default/blink.gif) This will be interesting to see if you can get all 4 or 6 outputs on the same screen. Or are you going to use a numerical index if the screen won't print nice lines? The Arduino microcontroller works at 16MHz. I don't remember the video resolution on that shield's screen. If that shield can't keep up with all 4 or 6 simultaneously ... If you used the Arduino and output the screen info to a Raspberry Pi (faster and HDMI video output) or BeagleBone (faster yet). Both are Linux single-boards. The RPi has the best video resolution by far. Or you could remote into either of the Linux boards with JuiceSSH (or something like it) and get the output on your laptop/notebook. I've only used the Arduino for stepper/servo/motor control and basic inputs like temperature, vibration, joysticks etc, and never played with a screen output directly from the Arduino. Very cool project on a really fun platform! Let us know. Good Luck The Arduino |
Lo-Fi Version | Time is now: 24th June 2024 - 07:43 AM |
