beemie96 |
Member ![]() ![]() Group: Members Posts: 98 Joined: 15-July 04 From: Nashville, TN Member No.: 2,350 ![]() |
Okay, I am planning to try to do as much work on this car as possible by myself (and beer-bribable friends (IMG:style_emoticons/default/beer.gif) ). With that in mind, I am thinking I should get an air compressor that can help me with grinding rust, removing stuck lug-bolts, and all the other great things air compressors do (like filling up tires for one).
I really don't need anything too fancy, but I want something that can run the guns effectively. I've seen some compressors for around $200. Example: This one had good reviews: (oil - less) Porter-Cable CPF23400S 3 HP, 4-Gallon Side Stack Compressor $192 And this one: (oil) Hitachi EC12 2-Horsepower Air Compressor - $239 Any pros / cons on the oil thing? What else am I going to need? I figure I'll need an air wrench and I want whatever kind of tool that Gint was using (pic attached) is that a grinder with a wire-cup brush? Looks like an electric actually... can I just run out and get one of those? Attached image(s) ![]() |
TonyAKAVW |
That's my ride. ![]() ![]() ![]() ![]() Group: Members Posts: 2,151 Joined: 17-January 03 From: Redondo Beach, CA Member No.: 166 Region Association: None ![]() |
I got this compressor
http://www.harborfreight.com/cpi/ctaf/Disp...temnumber=47065 in February and I have used i for a bunch of stuff, and so far its worked well. I have an air body saw which is great for removing rusty metal (as in your other thread), a 1/2 inch impact wrench, and a powder coating setup. For $200 or so you won't be able to get a huge or high horsepower compressor. So you will have to make do with a smaller one, which is fine if you don't mind waiting occasionally for a refill. In my case, with the tools I mentioned I basically don't have to wait. The duty cycle of my tool use is low enoguh that I sually happen to be done by the time it needs to refill. If I were using a grinder, or a sander I would expect that it wouldn't last long. I think Pep Boys has some good deals on compressors too. If you can afford to go up to the $300 or so mark there are plenty of nicer compressors. |
Lo-Fi Version | Time is now: 23rd June 2024 - 01:12 PM |
