Type 4 Engine Parts, Cranks, Performance Cams, Cases, 100mm Ps & Cs, etc |
greggearhead |
Oct 20 2013, 12:47 PM
Newbie Group: Members Posts: 35 Joined: 19-March 11 From: Colorado Springs, CO Member No.: 12,836 Region Association: None |
Lots of stuff - going through and posting as I go. So everything isn't posted yet, but will be!
Camshafts: All are aftermarket performance grinds, but appear to be fairly mild overall. FIVE performance cams for a T4 engine. Some markings are stamped, some are hand engraved. $50 each Engle F87 430 Lift 0.389" Engle 600/1324 Lift 0.385" Engle 430 T4-8, J 3 Lift 0.386" Blank - with a very small '69' stamped in, X 71R and P1212 hand engraved on other side Lift: 0.380" FF4/F 62 Lift 0.392" (IMG:http://www.914world.com/bbs2/uploads_offsite/i61.photobucket.com-12836-1382294848.1.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i61.photobucket.com-12836-1382294848.2.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i61.photobucket.com-12836-1382294848.3.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i61.photobucket.com-12836-1382294848.4.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i61.photobucket.com-12836-1382294849.5.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i61.photobucket.com-12836-1382294849.6.jpg) |
greggearhead |
Oct 21 2013, 05:50 PM
2073cc Type 4 Hot Rod 'Longblock' Engine
Not a complete longblock, but you get the idea. This is an older performance build that was used in a Sand Buggy in California. It has very cool, very rare EMPI 100mm pistons and cylinders. This was before everything was Chinese I think. They ALUMINUM FINS on a steel cylinder sleeve. This works great to keep the cylinders cool, but very expensive to make, so they weren't made for long and are hard to find. Unnumbered case - 66mm crankshaft and supposed to have a good mild mid-range cam. This is a great little engine to build upon, and with a compression mild, could be used in a bus, or in a 411/412 or 914, could be a great hot rod (with some headwork and a bigger cam). The 1.7L heads look good overall, and the valve sizes are stock at 39.3 and 33mm for intake and exhaust. Stock ports, so would be a great punchy engine. There are a few very small pieces of fin broken on one cylinder, and the bore of one cylinder looks to have a little wear on the bottom, but nothing that couldn't be run as-is or great with a hone and re-ring. $500 (IMG:http://www.914world.com/bbs2/uploads_offsite/i61.photobucket.com-12836-1382399445.1.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i61.photobucket.com-12836-1382399445.2.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i61.photobucket.com-12836-1382399445.3.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i61.photobucket.com-12836-1382399445.4.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i61.photobucket.com-12836-1382399445.5.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i61.photobucket.com-12836-1382399446.6.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i61.photobucket.com-12836-1382399446.7.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i61.photobucket.com-12836-1382399446.8.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i61.photobucket.com-12836-1382399446.9.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i61.photobucket.com-12836-1382399446.10.jpg) |
Lo-Fi Version | Time is now: 25th June 2024 - 12:09 AM |
