oil vs epoxy coils?, ...and other questions |
boxsterfan |
Oct 22 2013, 07:14 PM
914's are kewl Group: Members Posts: 1,776 Joined: 6-June 03 From: San Ramon, CA Member No.: 791 Region Association: Northern California |
I am looking at the Pertonix Ignitor II for my 74 2.0L. Pelican also lists the Flame Thrower II coil as recommended for this ignition.
However, they come in epoxy and oil filled forms? What's the difference? Also, I heard that if you switch to a Pertronix setup then you can not have your key in the on position and not starting the car (say to listen to the radio) for an extended period of time as this can burn out the coil. Is that true with the Ignitor II or was that true only with the Ignitor I? TIA...learning tons here. |
Mark Henry |
Oct 22 2013, 08:59 PM
I am looking at the Pertonix Ignitor II for my 74 2.0L. Pelican also lists the Flame Thrower II coil as recommended for this ignition. However, they come in epoxy and oil filled forms? What's the difference? Also, I heard that if you switch to a Pertronix setup then you can not have your key in the on position and not starting the car (say to listen to the radio) for an extended period of time as this can burn out the coil. Is that true with the Ignitor II or was that true only with the Ignitor I? TIA...learning tons here. Recommended because they want the sale, they work fine with the stock or Bosch blue coil. On MSD coils the oil filled tend to leak if you don't mount them upright and not on the engine. The epoxy high vibration blaster coil can be mounted any orientation and on the engine. I don't know if there's been issues with the pertronix coils. Hook the radio up to an always live circuit and just use it's on/off switch...just don't forget to turn it off when you park the car. |
Lo-Fi Version | Time is now: 31st October 2024 - 08:24 PM |
