> oil vs epoxy coils?, ...and other questions
boxsterfan
post Oct 22 2013, 07:14 PM
914's are kewl
I am looking at the Pertonix Ignitor II for my 74 2.0L. Pelican also lists the Flame Thrower II coil as recommended for this ignition.
However, they come in epoxy and oil filled forms? What's the difference?
Also, I heard that if you switch to a Pertronix setup then you can not have your key in the on position and not starting the car (say to listen to the radio) for an extended period of time as this can burn out the coil. Is that true with the Ignitor II or was that true only with the Ignitor I?
TIA...learning tons here.
boxsterfan
post Oct 24 2013, 10:10 AM
914's are kewl
I asked the question to Pertronix just for kicks....
They stated that the epoxy coil (on a Flame Thrower II) would be the proper application for the 914 since the coil is mounted horizontally. Of course, and correct me if I am wrong, but the original coil is oil filled and have worked in teeners for years and years and years.
Anyway, I understand Pertronix's answer....how could they answer any other way if their docs says "oil for vertical install" and "epoxy for horizontal installs" (in additon to high vibration and high heat applications). Of course, the epoxy is a few dollar more.... (IMG:style_emoticons/default/beer3.gif)
Jake Raby
post Oct 24 2013, 06:23 PM
Engine Surgeon
QUOTE(boxsterfan @ Oct 24 2013, 08:10 AM) *
They don't know. The last time I used one of their oil filled coils it erupted into flames.
boxsterfan   oil vs epoxy coils?   Oct 22 2013, 07:14 PM
Matt Romanowski   Key on not running would burn out points. It shoul...   Oct 22 2013, 07:28 PM
Dave_Darling   It's the Pertronix that gets burned up when yo...   Oct 22 2013, 07:30 PM
Mark Henry   I am looking at the Pertonix Ignitor II for my 74...   Oct 22 2013, 08:59 PM
Cap'n Krusty   In the 40 years I wrenched professionally, and the...   Oct 22 2013, 10:54 PM
boxsterfan   In the 40 years I wrenched professionally, and th...   Oct 22 2013, 11:32 PM
Olympic 1.7   FWIW... Many years ago ( when my car was running) ...   Oct 23 2013, 06:11 AM
eyesright   Hmmmm, Pertronics II... 1400 mile trip to Michiga...   Oct 23 2013, 07:54 AM
boxsterfan   Hmmmm, Pertronics II... 1400 mile trip to Michig...   Oct 23 2013, 10:11 AM
Java2570   http://www.pertronix.com/prod/ig/ignitor2/ Ignito...   Oct 23 2013, 09:15 AM
eyesright   Oil. And whenever you see oil leaking around the s...   Oct 23 2013, 06:59 PM
Jake Raby   Oil filled coils are particular to mounting positi...   Oct 23 2013, 07:23 PM
boxsterfan   I asked the question to Pertronix just for kicks.....   Oct 24 2013, 10:10 AM
worn   I asked the question to Pertronix just for kicks....   Oct 24 2013, 11:02 AM
Jake Raby   I asked the question to Pertronix just for kicks....   Oct 24 2013, 06:23 PM
boxsterfan   I asked the question to Pertronix just for kicks...   Oct 25 2013, 09:33 AM
Jake Raby   Mallory E coil... Which is what I always use and w...   Oct 25 2013, 09:01 PM
- Lo-Fi Version Time is now: 31st October 2024 - 08:20 PM
