machina |
Advanced Member ![]() ![]() ![]() ![]() Group: Benefactors Posts: 2,030 Joined: 21-June 03 From: Miami Beach, FL Member No.: 848 ![]() ![]() |
what a bitch these things are.
my first -6 fitting, didn't get the end cut 100% square, just a little off. Does this need surgical precision or is close enought OK? Next blunder, got 1/16" of "push out" as I threaded the nipple in. Can this really be done with 0 push out? Can I use this fitting splice as it is described above or should I keep practicing? Any tips? BTW, I am using a 3" cutoff wheel to cut the hose, the hacksaw blade technique was impossible, frayed like crazy. thanks, dr also, now I see why I need to get some Aluminum AN wrenches, scratched up my new fittings already. |
TimT |
retired ![]() ![]() ![]() ![]() Group: Members Posts: 4,033 Joined: 18-February 03 From: Wantagh, NY Member No.: 313 ![]() |
I wouldnt worry about 1/16 push out...try pushing the hose a teeny bit more into the fitting before you thread in the other piece. use lots of lube (motor oil etc), also hol one part in a vise and turn the other part
the best thing for cutting hose are these the 3in cutting wheel method leaves the hose full of rubber and bits of cutting wheel |
Lo-Fi Version | Time is now: 22nd June 2024 - 09:25 PM |
