first AN fitting, help me |
machina |
Jul 25 2004, 09:15 AM
Advanced Member Group: Benefactors Posts: 2,030 Joined: 21-June 03 From: Miami Beach, FL Member No.: 848 |
what a bitch these things are.
my first -6 fitting, didn't get the end cut 100% square, just a little off. Does this need surgical precision or is close enought OK? Next blunder, got 1/16" of "push out" as I threaded the nipple in. Can this really be done with 0 push out? Can I use this fitting splice as it is described above or should I keep practicing? Any tips? BTW, I am using a 3" cutoff wheel to cut the hose, the hacksaw blade technique was impossible, frayed like crazy. thanks, dr also, now I see why I need to get some Aluminum AN wrenches, scratched up my new fittings already. |
ArtechnikA |
Jul 25 2004, 01:15 PM
rich herzog Group: Members Posts: 7,390 Joined: 4-April 03 From: Salted Roads, PA Member No.: 513 Region Association: None |
QUOTE(TimT @ Jul 25 2004, 10:42 AM) Ive seen similar shears for around $35 at a local marine supply house i bought a cheap pair at Harbor Freight on the hope that they might work, and knowing that i had plenty of use for them in other applications if they didn't. they were junk on AN-6 braided hose but they did cut plastic irrigation line just fine. this is a place where cheap tools are no bargain... |
Lo-Fi Version | Time is now: 24th September 2024 - 12:57 PM |
