machina |
Advanced Member ![]() ![]() ![]() ![]() Group: Benefactors Posts: 2,030 Joined: 21-June 03 From: Miami Beach, FL Member No.: 848 ![]() ![]() |
what a bitch these things are.
my first -6 fitting, didn't get the end cut 100% square, just a little off. Does this need surgical precision or is close enought OK? Next blunder, got 1/16" of "push out" as I threaded the nipple in. Can this really be done with 0 push out? Can I use this fitting splice as it is described above or should I keep practicing? Any tips? BTW, I am using a 3" cutoff wheel to cut the hose, the hacksaw blade technique was impossible, frayed like crazy. thanks, dr also, now I see why I need to get some Aluminum AN wrenches, scratched up my new fittings already. |
TimT |
retired ![]() ![]() ![]() ![]() Group: Members Posts: 4,033 Joined: 18-February 03 From: Wantagh, NY Member No.: 313 ![]() |
intersting tidbit, this guy recommends using two very fine hacksaw blades mounted opposite each other in the hacksaw to cut the hose?
btw he also has some good prices on fittings |
Lo-Fi Version | Time is now: 22nd June 2024 - 08:56 PM |
